Hardcore Usage of UR Products: Testimonial!
EFN
Batu Caves
After 3 Autocrosses and some persistent agressive driving, I have to say that UR did helped a lot in my battle to reduce Understeer which is normal for FF cars. My ride is a 1993 Toyota Corolla AE101 and I have fitted a pair of Fender Bars, Rear Bar and 19mm Anti Roll Bar from UR - bought thru Stanley & HMS dealership - Good Services!. All I can say is that those UR bars will be staying there for good. Only my front strut bar is not from UR, simply becoz I used the JDM 2 Point Toyota from my first halfcut - which has been modded to be 3 points.
How good is good?
Well let's just say that traversing at the speed limit of my 4A-GE right now is pretty much predictable and controllable - even at long sweeping corners - no sway and no understeer - REMARKABLE! So much so that the only thing that gave way right now is lack of traction from my tires to keep up with the pace.
As for low speed low gear tight turns, those UR helped me to throttle up all the way to the rev limiter without feeling like the whole car being thrown to the sideways haaa
If you feel like driving to the limits, make sure your chassis is up to it. Call Stanley and he'll tell u how to "reform your car".
I am not getting paid for this, just that a good product deserves good rating.
i had the same thing, during long sweeping corners when i turn my steerin a little the car tends to be very sensitive...i wonder wat is that?? under or over?? :p
