Over Boost - Motorsports
Beyond 20,000 RPM!
GREDDY E-MANAGE ULTIMATE
The GReddy e-manage Ultimate is as close to a stand-alone management system as you can get while maintaining the best features of a "piggy-back" engine management; an economical price, the usage of existing sensors, the ability to easily alter factory settings and not having to tune from scratch. But unlike the original e-manage, the Ultimate is more refined for maximum tuning ability.
GREDDY E-MANAGE BLUE
GReddy’s e-Manage is a cost effective programmable engine management system that allows you to properly tune your factory engine control without having to change the entire factory ECU system to an expensive "stand-alone" unit or the inconvenience of sending it out for a full ECU reprogram. The e-Manage system is a true universal "piggy-back" type unit that taps into most Japanese factory ECU wiring, by utilizing the vehicle’s existing sensors (or optional upgraded sensors if factory sensors are maxed out). The major benefit is the factory ECU settings become your "Base-MAP" for tuning.
GREDDY V-MANAGE
GReddy V-Manage The V-Manage allows tuning of variable valve timing in older Honda VTEC applications where timing adjustments are "on-off" scenarios initiated by a solenoid or the newer generation iVTEC, Toyota VVTi and VVTLi, Mitsubishi's MIVEC and Nissan's CVTC that control the valve timing using a freer, progressive-rate strategy.
The V-Manage not only adjusts the crossover point or VTEC threshold but it can tune the amount of retard throughout the rev range. The unit uses e-Manage Ultimate software and interfaces easily with an e-Mange Ultimate computer to make seamless corresponding fuel adjustments. Also the unit has an auto-learn feature to determine the engine's baseline cam timing scheme and DIP switches that allow the user to quickly switch between stock timing and programmed timing.
PRICE
Greddy E-Manage Blue = RM 1,100
Greddy E-Manage Ultimate = RM 2,300
Greddy V-Manage = RM 1,900
Accessories / Harness = Please contact us for pricing, tq
http://www.overboost-motorsports.com/zthlogo.gif
CONTACT DETAILS
Address - No 28A, First Floor, Jalan PJS 11/7, Bandar Sunway, 46150, Petaling Jaya, Selangor, Malaysia (same row as N1 Racing, beside WRC Lighting)
E-Mail - [COLOR="Black"][email protected][/COLOR]
Tel - +603-5611 6628
Mobile - +6012-955 1800
Blackberry Pin - 2284DEF5
Website - OVER BOOST - MOTORSPORTS
MSN - [COLOR="black"][email protected][/COLOR]
Skype ID - overboost-motorsports
Facebook - Over Boost - Motorsports | Facebook
Mudah - PRO Niaga: Over Boost - Motorsports
CLICK HERE FOR CONTACT FORM
GREDDY V-MANAGE
PRICE
CONTACT DETAILS
boost sensor ( map sensor) for e-manage 5 volt, 3 bar.jpg103.4 KB · Views: 296 -
boost sensor (map sensor) for e-manage 5 volt, 3 bar..jpg83.5 KB · Views: 304 -
