Gauges!
wabbott
Wellington
What gauges are people running? boost, oil pressure, air/fuel etc?
upload some pictures if you can :burnout:
me NA... so water temp. oil temp. and oil press only
i only have boost, on the right side above dashboard.. there are alot of options.. there are ralliart din meter (boost, oil temp, oil press which taken from colt ralliart), and defi gauges with or without on dash cover, or you can replace our stock dash clock with meter and add 2 more besides it... i'll try to get some photos if i had one..
I used to have boost, turbo timer, shift lamp and Pivot V-Meter with speed, speed peak, G-force (front and rear), G-Force peak, 0-100m/200m/400m. I am not sure why Pivot doesn't add the 0-100kph feature.
Other than that, I have OBD II reader snap on if I drive long distance and use my cheap Lenovo to display all the parameters I need like water temp and A/F.
attachment.php
