GAB SUSPENSION - The Advance Technology Suspension
GAB SUSPENSION - THE ADVANCE TECHNOLOGY SUSPENSION
GAB SUSPENSION, the most advance suspension system with international worldwide quality and technology proven.
GAB SUSPENSION was established in year 1996 based in Malaysia. Our engineers and technicians designed and manufactured parts to the highest quality and standard ever produced in the market for all types of vehicles.
In year 2003, after a long period of Research & Development and thousands of kilometers driven and tested on road, we achieved a new level of success! Our project car; Honda Civic EK equipped with GAB SUSPENSION participated and clinched the MME 12-hour race title in Sepang International Circuit, Malaysia. Since then, the durability level of GAB SUSPENSION has never been any doubt for any motorsports enthusiasts. During the same year, we successfully designed, developed and produced the first ever suspension equipped with an unique technology known as the AVCS (Auto Valve Control Stability) done with the combination of both Japan and Malaysia technology and received tremendous response & praise from customers and users who equipped these suspension on their cars.
Our product range has since grown and today, GAB SUSPENSION has a comprehensive range of more than 1,500 part numbers with a high market coverage & availability. We are also a reputed manufacturer and exporter of suspension components in the Asia region. For being one of the suspension market leaders in Asia region, we were awarded with The Asia Pacific Top Excellence Brand Award by the Global Business Magazine and The Asia Honesty Award by Asia Excellent Entrepreneur Federation in year 2009 and 2013 respectively. With these awards and achievements, GAB SUSPENSION's legendary performance has once again proven to be the best ever suspension produced worldwide.
Even after 20 years of establishment, our passion and possibilities are still strong, high and infinite. Our enthusiasm will never fade away!
Products Lineup and Information:
GAB SS-R Series
GAB SS-R Super Special Racing Series - Fully Adjustable Hi/Lo Soft Hard with External Canister and Enlarged Monotube Suspension
GAB SS-R, high performance suspension are based on our advance technology and suspension tuning experience, cultivated in racing fields, is now directly applied to street and circuit for creation of this high performance flagship model; Super Special Racing. Top of the line in GAB SUSPENSION’s Series, for serious drivers who strive to race faster than others putting everything on line for one hundred of a second or even for one millisecond; purpose for street or circuit races.
32 levels compression / rebound damping force adjustment, 2 way independent ride height adjustment with external canister and enlarged monotube suspension
Features:
- Flagship model of GAB SUSPENSION; full potential exhibited at circuit
- 32 levels / steps / clicks extreme accuracy damping force Soft Hard adjustment (compression and rebound can be separately tune)
- Large monotube cylinder with 2 way independent height adjustment / High Low Body Shift
- External canister to cope with extreme heat, stable damping force and for cooling efficiency
- Specially formulated for circuit or street racing purpose with wide band of damping force adjustment tuning
32-Level Separate Damping Force Adjustment Feature
(rebound adjustment tuning adjust from upper piston rod / compression adjustment tuning adjust from canister bottom)
Design feature for rebound & compression adjustment set to be separately tuned for more precise and wide band of adjustment to meets driver / racer demands. Well established and for optimizing vehicle performance and providing wide band of setting capability specially formulated for circuit or street racing purpose. Equipped with 32-level separate adjustment feature, damping force is controlled at both base valve and piston rod for total of 1024-level (32 compression x 32 rebound) for finest setting capabilities. Specially designed advance needle valve controls damping force linearly at all level.
Optional Pillow Ball Upper Mount as Standard Equipment
6061 billet aluminum pillow ball upper mount with camber adjustment to meet driver / racer demands for the correct wheel camber angle, purpose for circuit or street race which suppresses the compliance, is designed for each vehicle applications, enabling direct driving feel, stable high speed circuit cornering and handling surpassing performance of OE mount. Special design offers AFDC compatibility. (except some models)
High KG Rated Performance Chromium Alloy Coil Spring
High performance chromium alloy coil spring are CNC-wound using the highest quality SAE9254 spring steel and corrosion protected using phosphate and powder coatings. Provided with high KG rated spring delivers best performance for circuit racing where no competitors can compete.
R.S.V. (Racing Speed Valve)
With R.S.V. technology, the required damping force in high speed range can be well maintained for better stability, minimizing body rolls, improving steering responses, road tractability and / or traction performance.
Enlarged Monotube Cylinder Structure
Enlarged monotube cylinder structure is used to enable very fine control of the machine and aggressive yet detailed communication with the road surface. This also enables to generate linear damping force capturing even the smallest information from road surface and to maintain stable damping force even after repeated sport drive. As oil and gas chambers are completely separated, aeration hardly occurs and heats are greatly reduced, achieving superb and stable performance.
Unique Design Forged Aluminum Spring Seat
Designed with multiple gaps that keeps the adjust wrench in place for easier ride height adjustment.
Carbon Thread Casing Cylinder (except some models)
All threading parts on cylinder cases are carbon coated with specially formulated fluorine for outstanding rust protection as well as for smoother ride height adjustment.
2-Way Independent Ride Height Adjustment
Use of moveable lower bracket allows for separate adjustment of ride height and pre-load, making it possible to secure sufficient stroke and more convenience to change pre-load setting. Allows separate adjustment of ride height & preload for finer setting. Ride height can be adjusted without changing spring preload.
High Rigidity Tensile Lower Bracket
Specially matched red color bracket, the forefront GAB SUSPENSION’s color to boost attractive under-carriage appearance looks. High tensile bracket maximize the lifetime, withstand lateral forces and ensuring perfect fitment.
External Canister Swivel Tank
For increased oil capacity in order to generate stable damping force at heavy load usage / circumstances, racing conditions and long distance. This structure is able to secure sufficient oil amount, promotes efficient heat release and excellence well performance at circuit.
2 Layers / 1 Bake Powder Coat & Rust Prevention
Before being sprayed with powder as the first base coat, electroless nickel coating & zinc phosphate are applied to lower brackets, the second layer of powder top coat is applied and then materials / parts are baked in a furnace for superior durability, corrosion resistance & highly effective against rust.
Optional Parts
Damper Turning Knob Extension Kit
To extend damper rate tuning knob where hand cannot be reach at certain place.
GAB SS Series
GAB SS Super Special Series - Fully Adjustable Hi/Lo Soft Hard Suspension
32 levels damping force adjustment and 2 way independent ride height adjustment monotube suspension
Features:
- Multi function state of art shock absorber
- Monotube design with 2-way independent ride height adjustment / High Low Body Shift
- Ultra high grip, comfort and traction, street & race use ready
- Widest range car models’ series
- Available model for more than 600 car application
New Design Reinforced Hard Rubber Silent Block Upper Mount (except some models)
Reinforced rubber mount, exclusively designed for each application, maintains calmness and comfort, yet enables direct driving feel and handling surpassing performance of OE mount.
32-Level Damping Force Adjustment Feature (compression / rebound together)
Well established 32-level damping force adjustment (compression and rebound together) for optimizing vehicle performance and providing wider setting capability on all kinds of roads; from streets, winding roads to highways. Specially designed needle valve controls damping force linearly at all level.
Optional Pillow Ball Upper Mont (except some models)
Pillow ball upper mount, which suppresses the compliance, is designed for each vehicle applications, enabling direct driving feel and handling surpassing performance of OE mount. Special design offers ADFC compatibility. (except some models)
Special PU Bearing (except some models)
To provide smoother turning, better steering response and to prolong lifetime of suspension.
A.S.V. (Advance Speed Valve)
With A.S.V. technology, required damping force in very low speed range can be well maintained for better stability, improving steering response, road tractability and / or traction performance.
High Performance Chromium Alloy Coil Spring
Hard Rubber Spring Supper Space
To ensure quiet ride, non-slip height adjustment and calm ride.
Use of moveable lower bracket allows for separate adjustment of ride height and pre-load, making it possible to secure sufficient stroke and / or to change pre-load setting.
Optional Parts
The angle of the camber can be easily adjusted to meet all the condition whether it is on the road or on the race track. Manufactured from highest grade 6061 billet aluminum, maximum driving stability and solid handling.
GAB SE Series
GAB SE Street Enhance Series - Fully Adjustable Hi/Lo Soft Hard Suspension
15 levels damping force adjustment and 2 way independent ride height adjustment monotube suspension
Features:
- 15 levels / steps / clicks extreme accuracy damping force Soft Hard adjustment
- High grip, comfort and traction for street
15-Level Damping Force Adjustment Feature (compression / rebound together)
Well established 15-level damping force adjustment (compression and rebound together) for optimizing vehicle performance and providing wider setting capability on all kinds of roads; from streets, winding roads to highways. Specially designed needle valve controls damping force linearly at all level.
Non Top Mount Design
To be used in combination with OE mount, for maintaining calmness & for reasonable pricing
Optional Pillow Ball Upper Mount (except some models)
Pillow ball upper mount, which suppresses the compliance, is designed for each vehicle applications, enabling direct driving feel and handling surpassing performance of OE mount. Special design offers ADFC compatibility (except some models)
2nd Generation AVCS (Auto Valve Control Stability)
With 2nd generation AVCS, more responsive and precise damping / rebound force is automatically tuned by AVCS-2 to suit all road condition. With the damping / rebound force automatically distribute by AVCS-2, you can now feel the difference on uneven road, bumpy road, pothole, high speed corners and highways. This results to superior handling and maximum comfort on all road condition.
E.S.V. (Enhance Speed Valve)
With E.S.V. technology, required damping force to maintained sophisticates ride comfort is control by ESV to suit all road condition. Thus, enhance handling with superior comfort & better stability.
Hard Rubber Spring Support Space
Optional Parts
GAB HA-B Series
GAB HA-B Series - Body Shift Height Adjustable Suspension
2 way independent ride height adjustment suspension
Features:
- Monotube design (except some models)
- 2 way independent ride height adjustment / High Low Body Shift
- Equipped with AVCS Auto Valve Control Stability technology
- Maximum height adjustment without compromise ride damping force & eliminate sound
- Superb handling, stability & maximum grip
- Extremely stable damping force even after long period of nonstop driving hours
- Able to withstand extreme road condition & long lasting life span
Monotube Design (except some models)
Monotube structure for delicate control of the machine and for dens communication with road surface. The use of monotube generates linear damping force, which reacts to even a tiniest input from road surface and stable damping force even after long period of nonstop driving hours.
Pillow Ball upper mount, which suppresses the compliance, is designed for each vehicle applications, enabling direct driving feel and handling surpassing performance of OE mount.
To be used in combination with OE Mount or reinforced rubber top mount, for maintaining calmness and for reasonable pricing.
With AVCS, you can now feel the difference on uneven road, bumpy road, pothole, high speed corners and highways. The damping and rebound force is automatically tuned by AVCS to suit all road condition. This results to superior handling and maximum comfort on all road condition.
Hard rubber spring support spacer
With multiple gap and keep helping adjust wrench in place for easy ride height adjustment.
Optional Parts
GAB HA Series
GAB HA Series - Height Adjustable Suspension
Ride height adjustment suspension
Features:
- Twintube design with height adjustment
- Superb handling, stability & sophisticates ride comfort
- Reasonable pricing
Twintube Structure
Twintube shell case is used for superior durability and for sufficient stroke and reasonable pricing. Compared to other brands, GAB SUSPENSION’s HA Series has larger oil capacity, wider shell case and piston rod for superb damping force characteristics. The use of newly designed piston valve and base valve also improves basic performance and sophisticates ride comfort.
Hard Rubber Spring Support Spacer
Titanium Thread Casing Cylinder (except some models)
All threading parts on cylinder cases are titanium coated with specially formulated fluorine for outstanding rust protection as well as for smoother ride height adjustment.
Thread-type Ride Height Adjustment
Threading type system enable adjustment by a millimeter, most suitable setting achieved for various situations. H.A.S. (Height Adjust System) is included as standard equipment for vehicles with separate spring / shock absorber set up to enable precise adjustment.
GAB SP Series
GAB SP Series - Cool Sport Lowered Spring
GAB SP, the advance technology cold forming sport lowered spring are designed to dramatically improve handling performance and driver feel by significantly increasing corner grip and reducing body roll. These sport lowered springs are CNC-wound using the highest quality SAE9254 spring steel, shot peen stress relieved and corrosion protected using phosphate and powder coatings. Each spring is designed to optimize the balance between performance and comfort. These results to a spring that offers racer like handling yet maintain smooth and comfortable ride characteristics. These sport lowered springs can be equipped with factory or aftermarket shock absorbers and looks great on vehicle with stock or aftermarket wheels. Average drop is approximately 30mm - 40mm. When applicable, it is recommended to use the GAB SP Series Cool Sport Lowered Spring with GAB SA Series Heavy Duty Sport Absorber and other fine GAB SUSPENSION’s components.
Features:
- Made of Chromium Alloy SAE9254 Steel
- Manufactured with Advance Cold Forming Technology
- Perfect spring rate for each vehicle
- Average of 30mm to 40mm drop from stock spring
- Passed 500,000 times of compression test
In contrast to hot forming where the spring is coiled at an elevated temperature, our sport lowered springs are made through the technique of cold forming (normal temperature forming at a non-elevated temperature). By using a dedicated new-type coiling machine, deterioration of the material is prevented and advanced performance is retained.
Chromium Alloy Spring
Springs are made of chromium alloy SAE9254 steel and passed 500,000 times of compression test and inspection with less than 5% deformation.
Easy Low Down Red Spring to Brightly Decorate Your Suspension
Produced for an easy and pleasurable suspension tuning with sporty driving for everyone. Designed and developed to offer improved driving performance and superior ride comfort. It is constructed by using material with tensile strength of over 200kgf/mm2, yet is offered at a reasonable pricing under through cost management.
Improved Rust Prevention
The surface is treated with powder coating which forms thick film and is highly durable in addition to zinc phosphate coating as pre-paint. This results in a very effective rust prevention where such paint provide superior protection against snow melting agent (calcium chloride) compared to existing paint solvent.
Silencer Rubber
To prevent noise cause by coil-to-coil contact and / or from mounting portion, the silencer rubber is applied to each spring in reducing unpleasant noise commonly caused by the use of lowered springs (except some models)
Perfect Spring Rate
The spring rate setting is perfectly designed for each vehicle to optimize comfort level and look appearance.
Average of 30mm - 40mm Drop
By using the GAB Sport Lowered Spring, the ride height average drop compared to stock spring will be 30mm to 40mm.
GAB SA Series
GAB SA Series - Heavy Duty Sport Absorber
A whole new level of shock absorber; well balance, heavy duty, long life and equipped with AVCS technology to provide maximum traction and comfort.
Features:
- Heavy duty & longer life span
- Well balance heavy duty sport absorber
- Maximum grip and traction while comfort level remains
- Compatible with all type of springs
Heavy Duty & Durable
The GAB SA Series heavy duty sport absorbers are designed to withstand all types of road conditions for your driving pleasure and experience yet provides a longer life span; durable.
Handling Improvement & Comfort
On uneven road conditions, the absorber will effectively absorb the impact and vibration which results to a more stable and comfort ride and at the same time provides maximum grip and traction.
Compatible with All Type of Springs
Unlike standard shock absorber, GAB SA Series heavy duty sport absorbers are compatible with standard spring and sport lowered spring without sacrificing ride comfort and absorbers’ life span.
Satisfaction Guaranteed
Superb handling, high stability, durability and comfort are to be guaranteed for your satisfaction.
GAB 4X4 S Series
GAB 4X4 S Series - Damping Force Adjustable Absorber for Pick-Up & Trucks
4 levels damping force adjustment suspension for Pick-Up & Trucks
Features:
- 4 levels / steps / clicks damping force Soft Hard adjustment
- Heavy duty & longer life span oversized piston and cylinder; suitable for off-road and normal drive
- Better traction control, stability and comfort
4-Level Damping Force Adjustment Feature (compression / rebound together)
Well established 4-level damping force adjustment (compression and rebound together) for optimizing vehicle performance and providing wider setting capability on all kinds of activities; off-road and / or normal drive. Specially designed needle valve controls damping force linearly at all level.
Heavy Duty & Durable Oversized Piston and Cylinder
The GAB 4X4 S Series damping force adjustable absorbers are designed with oversized piston and cylinder to withstand all types of activities; from normal drive to off-road for your driving pleasure and experience yet provides a longer life span; durable.
GAB ADFC
GAB ADFC - Advance Damping Force Controller
GAB ADFC, the in-car damping force controller that makes it possible to adjust the damping force of the suspension with ease from the driver’s seat. By having the stepping motors installed on each shock absorber, an easy yet instant adjustment at fingertips allows varieties of damping force settings to be done under different types of situations and weathers to suit all road conditions.
Features:
- High speed stepping motors; 1 click in 0.18 seconds
- Compact controller & high visibility; adjustable LCD brightness
- Memory recall / resume function
- Self diagnose function for system error
- 900 different damping force settings
High Speed Stepping Motors
The stepping motors for GAB ADFC are highly accurate and controls piston rod in high speed of 0.18 seconds per click. It is designed and made rigid for heat and shock resistance in addition with a special rubber cover as protection against water and dust.
Compact Controller & High Visibility
Illumination on display offers high level of visibility even at night time. The controller is compact in size which allows you to install at any possible location of your choice and is made of superior heat resistance material, ABS resin. The brightness levels of the LCD are adjustable as well to suit your needs.
Remote Stepping Motor Extension Kit
With the remove stepping motor extension kit, you do not have to worry about the limited and compact space available in front hood / rear storage compartment for all type of car models. The stepping motor can be mounted at a suitable place with the extension kit connected to the shock absorber.
900 Different Settings for 30-Level Type
900 different damping force settings can be adjusted accurately with ease from driver’s seat under different types of situations and weathers to suit all road conditions.
Memory Recall / Resume Function
This function allows you to preset and instantly recall the damping force setting; Race, Sport and Comfort mode to suit different types of road conditions. The GAB ADFC uses accessory power to keep it constantly on, to memorize the last setting and to resume it the next time engine is started which eliminates the need to readjust again.
Available In 2 Types: 15-Level & Finer 30-Level
The GAB ADFC comes in 2 types; 15-level and finer 30-level for different GAB SUSPENSION’s products.
Social Networking Sites:
Facebook: GAB SUSPENSION
Instagram: http://www.instagram.com/gab_suspension
Website: GAB SUSPENSION
