GAB product (BRAND NEW), hi-low adjustable, absorber, spring
bro,gimme price for sports abs for 1.6 satria - fronts only???
Can you pls quote me the price of GAB Adjustable Suspension for Satria 1.3 but just mod to Mit 6A10.
How will the installation work?
How do I know it will be suitable?
My engine a bit heavy in front.....
How is the adjustment to be done...?
Can help to explain a bit.
Thanks.
E-mail at : [email protected]
if using GAB adjustable HI-LOW suspension (2nd generation)
do i have to use the sport spring seperately
how much for wira se (full set) including installation
Izso said:
Calvin, Hi/Lo AVCS + spring for Wira A/B SE how much? I heard the SE version of springs is diff from the standard A/B. Price please
bor calvin,
need some info like above... PM me please..
PM me set of GAB spring and adj hi-lo suspension for gen2
thnx...
hey man, if i use gab adjustable hi-low suspension, is it required to purchase sports spring? how much for full-set (front & back) for proton saga (megavalve) and is installation provided?
pm me...thanks!!
calvin00cool said:
http://pg.photos.yahoo.com/ph/calvin00cool/detail?.dir=5b16&.dnm=96cfscd.jpg&.src=ph
1)GAB adjustable HI-LOW suspension (2nd generation)
wf AUTO VALVE CONTROL STABILITY (AVCS) system to suit in all road condition whether uneven road, bumpy road, pothole, high-speed corners and highways.
AVCS= internal system that adjust the stiffness of the suspension using multiple layer valve spring to sense the road condition and auto reduces n increases damping forces according to road condition and driving style. it also enable the constant and auto change of suspension stiffness rate.
result: SUPERIOR handling and maximum comfort on all road condition.
*its gas filled type ...so it will nv occur any oil leak problem.
2)GAB lowering sport absorber...can pair it wf ur OEM spring...can purchasefront set or in a set ....
3)GAB lowering spring...can pair it back wf ur oem absorber....
im selling for various car model as well...and it comes wf warranty 1 year.
for pricing,please PM me or call me at 0122199169.
#dealers are wecomed
(this is GENIUS GAB item taken direct from GAB MALAYSIA SOLE DISTRIBUTOR)
HI there i would like to ask wether the GAB absorber can be fitted to WIRA car?>......what about the front suspension?..can it be fitted to like in the pic?>
AvexTrax said:
bro..pm me the price for satria 1.6
thanx
calvin, same quotiation... need to know separate price for front set and rear set together with springs...
and if you have GAB springs can you quote me the rear one? Hi-lo/Soft Hard GAB adjustable rear..
hey man...please quote me the price for this few items listed..thanx ;)
1. GAB absorber for wira 1.5...front and rear
2. GAB lowered springs for wira 1.5
for item no. 2..how much will it lowered our car?how many fingers in between the wheel and the arch?
