Fuel saving,Better RPM response,Increase engine torque,Optimized all electronc device
madkean
i-CHARGE Voltage Stabilizer has the following three systems:
• Voltage Stabilizer System
• Interference Reducer System
• Battery Doctor System
Benefits
• Fuel saving
• Better RPM response
• Increase engine torque
• Engine power up
• Optimized all electronic devices in car
Notices
• Do not disassemble or modify this product to avoid damage or injury.
• Only design for 12V vehicles. Do not use on 24V vehicles.
• Do not plug in and out from the cigar-lighter socket during driving.
• When install, please make sure the plug of i-CHARGE is securely in contact with the socket.
• If the cigar-lighter socket is loosened due to previous usage of other charging device, please adjust the contact point inside the
socket before plug in.
• Fuel saving effect will differ according to car type, driving behavior, weather, road condition etc.
Advantages
• Faster throttle response, engine power up.
• Reduce car CPU noise signal, improve CPU reaction time, improve electronic efficiency.
• Smoother gear shift on automatic car.
• Improve engine power, better acceleration response, hence improve fuel saving.
• Maximize ignition efficiency, easier engine start.
• Prolong engine and electrical device life-span.
• Easy installation, totally DIY, the first choice for ladies drivers.
• Universal for all cars and motorcycles
• Reduce noise with built in noise filter, improve sound system performance.
• Equipped with double fuse protection, for better product life and safety.
• Faster RPM response, it gives you powerful acceleration even when your car's air condition turn on to maximum load.
• Cleaner exhaust emission on HC and CO gas. So more environment friendly.
• Twelve (12) months Limited Product Warranty.
more info ?
http://www.zeromax.biz/eng/e_product_max_01.php
http://www.hmetro.com.my/Current_News/myMetro/Tuesday/Vroom/20080701100542/Article/indexv_html ïƒ* lihat paper pasal product ni, date 3 july 2008
Re: Fuel saving,Better RPM response,Increase engine torque,Optimized all electronc de
Pm the price bro
Baru Bermula: Gabungan diantara keperluan dan permintaan. Gabungan diantara kekuatan produk dan plan. Produk yang hadir dimasa yang tepat dan plan yang membolehkan anda mendapat pendapatan yang lumayan. Anda buat anda untung, anda TAK buat pun anda TETAP untung.
INGIN TAHU BAGAIMANA ANDA TETAP DAPAT UNTUNG, SILA LAYARI LAMAN WEB BERIKUT SERTA DAFTAR "PERCUMA" DI http://www.rebetminyak.com/abcdead
SEGERA BERTINDAK!!!!!! JANGAN BIARKAN ORANG LAIN MENGAMBIL PELUANG LEBIH DAHULU DARIPADA KITA. TIDAK PERLU TAKUT KERUGIAN SEBAB ANDA AKAN TETAP UNTUNGGGG!!!!!!!!!!
