FS: FD3S Trust T88-34D turbo kit
cqloh
Trust Greddy T88-34D turbine, used but in very very very good condition.
This is a serious upgrade for FD RX7 owners!
1x Trust T88-34D turbocharger with #22 exhaust housing
1x Trust 58mm racing waste gate
1x Trust exhaust manifold
1x Intercooler (intercooler piping is excluded)
Gaskets and hoses to suit also included.
RM8000 ono
Talk is cheap. will let pictures speak for themselves.
Call Kelvin @ USJ Auto Services
012 210 3322
the turbo is rated to 800 plus Hp.. but you would be hard pressed to see something like that from a 2 rotor.
with good compression in all 3 chambers in both rotors (95psi and above), proper fueling, ecu etc.. you'd get mid 400 easy. this is with stock ports and pump gas.
the guys in australia and the states make 600hp.. but obviously with race gas, extended ports, tougher apex seals, doweling etc etc etc
same kit used by RE amemiya, Veilside and most top rotary tuners in japan.
Nice stuff you have. I will contact you tomorrow. Btw, 22cm2 means A/R?
yeap.. thats mitsubishi's way of rating the A/R. i guess they just wanted to be different from garrett or something along those lines. =)
thanks to those that have inquired about this product!
to answer some questions:
this kit is second hand from japan with very little mileage..
if you;re worried about the lag.. a smaller turbine housing can be easily sourced!
