http://mobile.jlaudio.com/graphics/SUB/W6v2_HP_MI.jpg?0.38001486219291736
Reviews
W6v2 Technologies
Recommended Power ChartTutorialshttp://mobile.jlaudio.com/graphics/SUB/W6v2_Quote1.jpg?0.6722018144551538
What if the compromises inherent in speaker design could be negotiated to create exceptional sound quality and output in very compact enclosures?
What if you could apply years of intense research and vast experience in subwoofer driver design to such a project?
What if the freedom existed to engineer every component of the new design from the ground up?
You are looking at our answer to these questions, the W6v2 drivers.
At first glance, you’re likely to notice the striking cast alloy frame design. These frames are much more than cosmetic enhancements, having been specifically engineered to provide increased clearance for greater excursion and to incorporate our patented Elevated Frame-Cooling technology. This cooling scheme directs high-velocity air flow over the top surface of the top-plate and onto the upper portion of the voice coil windings (the two hottest parts on a woofer). For style points, the mounting flange of the frame is dressed with a removable black trim ring (Patented) which can be painted to match the theme of the installation.
Like the W7’s, the W6v2 subwoofers benefit from JL AUDIO’s proprietary Dynamic Motor Analysis system (DMA). This advanced technology allows us to optimize motor behavior, while taking into account the effects of real power flowing across the voice coil. The result is dynamically stable and linear motor behavior, which translates directly into reduced distortion and improved transient performance.
The diaphragm design also relies on W7 technology, utilizing our W-Cone™ (Patented) design and Floating Cone Attach Method (Patented). This results in a lightweight, stiff and critically aligned moving assembly (again enhancing sound quality). The diaphragm also incorporates a new (Patent-Pending) “NeckVent” design to enhance cooling performance.
Co-extruded, insulated lead wires lead to a configurable patch panel which makes it easier and cleaner to interconnect the dual voice coil windings. A single pair of high-grade push terminals acts as a main input connection.
All this technology comes together to deliver subwoofers that excel in thermal power handling, linear excursion capability and dynamic stability; all of which contribute to the original goals: The ability to have amazing low-frequency extension in compact enclosures, razor sharp definition of complex bass material and audiophile sound quality at any volume level...
...in other words, the balance of power and finesse.
All W6v2 Subwoofers are built, with fanatical attention to detail, in our Miramar, Florida factory.
Available Models:
10W6v2
12W6v2
13W6v2
http://mobile.jlaudio.com/graphics/SUB/10W6v2_MotorSmall.jpgHighly Linear, DMA Optimized Motor System
Highly optimized motor system delivers linear motor force over a wide range of excursion and power levels to reduce distortion. more info...
http://mobile.jlaudio.com/graphics/SUB/10W6v2_WconeSmall.jpgW-Cone™
(U.S. Patent #6,496,590)
A unit-body cone assembly that delivers astonishing cone stiffness with minimal mass. http://mobile.jlaudio.com/products_subs_pages.php?page_id=55http://mobile.jlaudio.com/products_subs_pages.php?page_id=62http://mobile.jlaudio.com/products_subs_pages.php?page_id=60Elevated Frame-Cooling
(U.S. Patent #6,219,431, #6,229,902))
Provides additional cooling by directing air flow over the top-plate and onto the voice coil windings. http://mobile.jlaudio.com/products_subs_pages.php?page_id=60http://mobile.jlaudio.com/products_subs_pages.php?page_id=56
http://mobile.jlaudio.com/products_subs_pages.php?page_id=59NeckVent™ Cooling
(Patent Pending)
Vents at the neck of the lower cone body work in conjunction with the pole vent's air flow. more info...http://mobile.jlaudio.com/products_subs_pages.php?page_id=55http://mobile.jlaudio.com/graphics/SUB/10W6v2_FCAMSmall.jpg?0.15416676412542063Floating Cone Attach Method (FCAM)
(U.S. Patent #6,501,844)
Ensures proper surround geometry and moving parts alignment in the assembled speaker. more info...
http://mobile.jlaudio.com/graphics/SUB/10W6v2_SpiderAttachSmall.jpg?0.01070744584079275Plateau Reinforced Spider Attachment
(U.S. Patent #6,118,884)
Provides strain relief for the spider material at extreme excursion levels. http://mobile.jlaudio.com/products_subs_pages.php?page_id=58
http://mobile.jlaudio.com/products_subs_pages.php?page_id=62Large, Progressive-Roll Spider
Optimized to control the long excursion of the W6v2's without limiting it. http://mobile.jlaudio.com/products_subs_pages.php?page_id=62http://mobile.jlaudio.com/products_subs_pages.php?page_id=59http://mobile.jlaudio.com/products_subs_pages.php?page_id=63Engineeered Lead Wire System
Provides ample stress relief and lead wire control without compromising spider integrity. more info...http://mobile.jlaudio.com/products_subs_pages.php?page_id=60http://mobile.jlaudio.com/graphics/SUB/10W6v2_JumpersSmall.jpgTerminal Jumper System
W6v2's employ a unique voice coil configuration terminal to simplify connections.
http://mobile.jlaudio.com/products_subs_pages.php?page_id=64
http://mobile.jlaudio.com/products_subs_pages.php?page_id=63http://mobile.jlaudio.com/products_subs_pages.php?page_id=56Customizable Trim Ring
(U.S. Patent #D480,709)
This removable ring can be painted to match the installation theme and is also designed to receive grille mesh inserts. more info...
Reviews
W6v2 Technologies
W6v2: Technologies
http://mobile.jlaudio.com/images/spacer.gifhttp://mobile.jlaudio.com/images/spacer.gifW6v2 Subwoofer DriversWhat if the compromises inherent in speaker design could be negotiated to create exceptional sound quality and output in very compact enclosures?
Available Models:
10W6v2
12W6v2
13W6v2
(Patent Pending)
