jswong said:Wah, can weld directly?
In my car, I got two holes drilled for the forward arm of the 3-point bar.. that portion sits between two steel sections of the car body. Seems like the front part of the 3-point bar ties the two sheets together..
How to weld it directly? If the bar is welded on, do we need to weld that two steel sections also?
seisuichai said:just asking.....if now i buy the 3 point fender bar for my new saga... next time when i sell the car...can i transfer it to my new car...say perdana or vios?
thanks man...calvin tong said:cannot.. coz is different..
whatdamn said:just get the fender bars la. don't drill holes, just weld the buggers on. ur cornering will be freakin good man. :) i welded mine on and no other bars except the anti roll bar (stock) will give you real good feel.
GRexer said:Calvin, how much do u charge for welding the bars on? Mine is already installed, but would like to change from the bolt-on, to weld on for the point on the fender. Mine's a 2-point older model.
e39a said:just wanna ask, when u weld the bar to the fenders, i sssume u weld on the front part, the other 2 parts are clamped together with the door hinges, so how to remove next time, if wanna change doors?
cheers
speedking said:calvin tong, check ur pm bro :)
| Yokohama’s Street Sport Tire ADVAN NEOVA AD08 to be Released |
