i think can....the painting shops can do for u but if DIY i am not sure how to do?? even my car got holes from previous side skirt (now removed) i dont know hw to close those holes as i can't access from inside , the holes are on the body of the car right near the place where the door sills are...i also want to DIY & close those holes as they are rusting
can, its definately possible cause i have DIY it before
but it will be costly, so i suggest u go to those paint shops
what i did was buy fiber resin and fiber cloth from ACE hardware
fiber the hole from underneath then buy poly putty from any paint supplier and putty the hole up
nicely done and u wun even know there was a hole there after respraying the thing
that one arrr.......
u lum u larrr ( u think urself lar )
actually it is still possible
here is what i was just thinking
maybe u can use the type of fiber that is jelly like (this one can get in any automotive paint supplier) and the stuff it in, and when it dries, u will have the base to hold the putty,
then u can putty and sand it to perfection
never tried this before but its an idea
just send your car to the painting shop la .. they can do it ... my car got 8 holes the size of 20 sen coins ... they weld the hole shut then but putty it to be flat .. cost me RM150 for my whole boot with spray.
this is the problem from simply putting cheap bodykits...they spoil easily and leaves hole on the car body from bad workmanship and design...see other well established design uses Nuts and bolts...
so u can remove it without seeing holes and the quality is better for durability also...
Dear all, I'm searching for replica or second hand sport rim for my lance GT. Got a few in my mind, TE37, CE28 or any rims color come with Bronze or Gold.
