Exedy Racing Clutch
Exedy Racing Clutch
G1Racing
Penang
Thick cera-metallic friction material + Reinforced clutch cover. Suitable for drift, rally, circuit & street usage. SPECIFICATIONS: Single Plate Cerametallic EXEDY cerametallic clutches are designed to handle the abuse of high power modified engines. Our cerametallic friction material can handle much more slippage than stock type disc assemblies without slipping and fading. All EXEDY cerametallic clutch discs have spring center dampers to reduce the impact and shock loads put into the drivetrain.
This protects the transmission and the rest of the drive line system. We offer two types of cerametallic discs - normal thickness and reduced thickness. The reduced thickness (thin cerametallic) discs offer greatly reduced inertia to improve shift efforts, make for faster shifting, and improve synchro durability. These discs are approximately 1/2 the thickness of a stock disc and is recommended for track only.
The normal thickness (thick cerametallic) discs have better heat capacity and therefore better durability in demanding applications such as all wheel drive. Even with the normal thickness, our three puck cerametallic discs still typically have less inertia than a stock disc and are good for street and track. With any cerametallic clutch system, there will be some compromise of start up driveability as compared to a stock clutch (chatter on light throttle, low rpm start up).
This characteristic is generally felt to be acceptable in modified performance cars. Drivers of cerametallic clutches on the street should be warned not to 'ride the clutch' to try to reduce the chatter as this will greatly increase the wear
100% Genuine product , or guaranteed double money refund !!
PS:Price Quoted as per set
Loc :
NO.1307, JALAN BARU,
TAMAN CHAI LENG PARK,
13700 PRAI, PENANG.
Business Hour :
GPS Location:
E 100* 23" 22.6'
N 5* 23" 1.6'
Facebook : G1racing
Payment Transaction:
1.Maybank 2 U.
2.Bank in Cash.
3.Bank Account TT.
47500 Subang Jaya, Selangor
