EPS Power Charger
EPS Power Charger
andysky5
((( God Level 30,000 RPM )))
EPS Power Charger
Modern day cars are all dependent on electrical supply for the numerous electronic components such as ECU, spark plugs, radio, sensors, electronic throttle bodies, lights, rain sensors, cruise control, electric seats and etc. This puts more strain on the car’s electrical system especially the battery and alternator.
The car’s battery will be the main source of electrical power with the alternator providing the charging effect to enable the battery to supply regular electrical power the electrical components. With the escalating battery prices due to escalating raw material prices, vehicle owners will try to find ways to preserve their car’s battery life.
Through the charging effect of the alternator the car’s battery is only being charged when the car is driven. The alternator being engine driven usually robs the car’s engine of at least 5% to 10% of power. This in turn increases fuel consumption and cuts the power of cars with small engine capacity.
The Power Charger is a revolutionary electrical booster than assist the battery and alternator by way of reducing the resistance between alternator and battery thus allowing the battery to be charged easily. This reduces the load on the alternator which in turn reduces the load on the engine thus freeing up the power for the engine. With more efficient battery charging, the battery life will be extended and the car will experience more performance efficiency as a whole.
- Stabilizes the power system, and excels the electrical discharge efficiency.
- Reduces the noise interference to the electrical system, thus extending the life of electrical components.
- Instant performance, pickup, Power & Torque.
- Improve acceleration and responsiveness.
- Improves car ignition, and saves the fuel.
- Reduces Fuel Consumption 5-20%
- Instant improvement on Battery Cold Cranking Ampere (CCA) performance & prolong lifespan.
- Easy to Install can DIY, installation Instruction Provided.
- Warranty Provided
Offer Price : rm459
Interested pls. pm or call : 017-3526055 (andy)
Dealing method : COD at Kelana Jaya/Sunway or Send by Postlaju.
CLICK HERE to check out my other sales Item !! :burnout:
Thanks for Viewing !!
