The button got nothing to do with the 'CHECK ENGINE' light before crank.
The button functions as if you turn your key to START/CRANK. You will still need your car keys to turn to ON position and later you can choose either the button or turn the key to start it.
bro,,how to pull out the button from the wire conection relay part...i mean the button part only...just pull like that or there is the way to do it....
hi bro... got the button from you bout 2 weeks bek or so many thanks to you for the prompt respond and fast delivery... and definitely no complains for the price.....just wanna enquire from you... am a bit curious although i dont dare to try.... lets say i start the engine with the button.... and then engine is running.... then suddenly i "ter"- press the button will the it start cranking again or is there a saftey built in the device to not activate the cranking? many thanks
cRuZ1011, Thanks for the feedback.
The push button is exactly like when you turn your key to crank. I advice you not to push the button when the engine is already started. There is no safety device built-in the button as it has no complicated electronics setups. The only way to avoid such accident crank is to place the button far from your itchy hands when you are driving. :P
