hi,
my wira just change engine gsr 4g93 turbo.
the engine is vibrating & shaking badly at idle. idling 900rpm steady. above idling no vibrate.
mounting looks good.
also the spark plug should i use heat range 6 or 7 ?
as i know , throttle body dirty might cause rpm to dance up and down
but my rpm is steady, just the whole engine vibrating badly
on the road, the power is normal for a stock gsr
hi all sifu. can help me to differentiate the ecu for 4g93p code 0453 is mmc or svdo. i check my ecu i cant reach it and only can find this code and i google din find any about it. thank you!
