i have a problem with my engine. bad idle. check engine light blinking shows code 4 2. refer to the gti diagnostic chart, it means crank angle sensor. what should i do. anybody can help me?
problem fixed. found no.1 spark plug melt. i replace the spark plug and the check engine light clear. it happened when in a hi rev. i don't know why the spark plug melt. it happened to me 2 times. only no.1 spark plug :hmmmm:
If I'm correct, your head gasket should be faulty this moment ...... You can try to send your car to workshop and have engine compression check see all 4 cylinders have the same compression reading.
having read many posts on tyre choices and feedback id like to humbly ask for one from you guys. am currently on RE001 (195/50/15 fronts, 205/50/15 rears) and am looking at upgrades. the car is a RWD daily...
