Engine Parts. Update With New Items, 10/4
Joeker
Walking Dead
Jinjang
1.) 4G93 GSR Conrod. RM150
2.) Perdana SOHC Sei Throttle body. RM100
3.) 4G92 Vacumn Brake pump. RM100.
4.) 4G92 SOHC Injector 182cc. RM100
5.) 4G92 DOHC Injector 210cc. RM150
6.) Narrow band 02 sensor for air fuel ratio meters RM50
7.) 4G92 SOHC fuel pump RM100
8.) 4G13/15 12valve stock carburator RM50
019-684 1500 or 016-908 4695
4G93 GSR crank shaft. SOLD
Can't see which part that has been ligthened nor jack-knifed? :huh:
haiyaa can see the jack knifed.....
u can see ka??? ;)
sudah potong how much???
mr Joeker. HOw much roughly wud this thing cost to install ?
Comparison against a stock crank. THe difference is in the counter weight and crank journal.
bro can it fit intu 4g92 block or just for 4g93
Wah Joe! Changed engine already ar? :o
dfactor,
Which item do you want to fit into block?
Aaron,
Still same lame 1.6 :(
Can include shipping fee 2 Sabah the knn filter? :D
4G92P Vacumn Brake pump. RM100
http://zerotohundred.com/forums/uploads/post-47-1098863679.jpg
Hi there,
Well my ride is satria 1.6
can you tell me who to check my throttle body with working or the ISC is working.
What the function of the ISC?
thanks
muff
Originally posted by Joeker@Mar 12 2005, 22:28
Proton 1.6 Throttle body with working ISC, RM200
[snapback]812212[/snapback]​
ISC = Idle Speed Control.
WHen ISC is not working well, idling will be unstable (too low or up~down~up~down) especially wtih air-con on.
Yes. 1.6 Satria will fit perfectly.
thanks
Which means if i on my air cond and the rpm is on 2 or 3 stable means my ISC is working alright?
Can save Rm200 for sumthing else whahahaha
muff
[snapback]847146[/snapback]​
I don understand........
do you mean 2,000~3,000 RPM? I think its too high an iddling.
