EASYCAR Luxury Smart Key System (Keyless Entry)
DBL-Vie Auto
We are extremely proud to introduce the latest Car Security System E702 'Luxury' installed with the most remarkable function. E702 'Luxury' is featuring on its TFT LCD display panel the very first time in car alarm systems. LF technology that makes car armed/locked when person with remote is closer/away from the car at 1.5 meter at sharp LF technology makes its working boundary very accurate & smart key system any person can not start the engine if he/she does not have the remote control. This unbelievable high quality product is simply more than wonderful & definately irresistable!
TFT is the latest, most advanced display technology and it's slim contoured body featuring product E702-AS-S is truly amazing!
TFT-LCD ( thin film transistor, liquid crsytal display ) is the latest display technology in the market. Owing to it's best brightness and resolution other display types can not beat, it's became widely used panel these days on Mobile, Pda and Lcd Tv etc.
THE FOLLOWING REMARKABLE FEATURES ARE NEWLY ADDED IN E702AS​
SmartKey5%20modified.jpg http://sitebuilder.yola.com/sites/S3/D838/D16e/D360/De7a/U8a4986cb22a737a50122a7e063e61838/8a4986ca22d2804e0122e5cd3cca17f7/resources/keyknob.jpg?timestamp=1267448113265
SMART KEY SYSTEM
Can't Get The Engine Started With Car Key
Provided with smart key knob seen right, your remote will work just like smart keys in those LUXURIOUS cars such as MERCEDES.
For whatever model you have, no one can not get the engine started with your car key stolen from you, if there is no remote control inside the car.
No Additional Remote setting after installation needed. Your remote will work just like smart key.
  • Capped with luxurious smart key knob, the key is always being inserted in the key box.
  • That means you don't have carry the car key. It is simple and easy.
  • Without remote control, you cannot get the engine started with car key even if it is inserted in 'ON' position or door is open.
SMART DOOR
This technology makes the door unlocked when the car owner with the remote approaches the vehicle and locks the vehicle when the car owner with the remote is far enough away from the vehicle.
Exciting and New LF technology is now available. Utilizing a highly stable L.F. signal, the proximity locatore will consistently unlock or lock your vehicle as you approach or move away from the vehicle.
No longer fumble for your key or transmitter when your hands are full. Customers enjoy our new convenience..., you will too.
AUTO SIDE-MIRROR FOLDING
It Folds Itself When Locked/Armed
Either by remote or digital key pad Easy Door Lock, your side mirror works simultaneously with it.
Side-mirror folds when car is locked/armed and unfolds when car is unlocked/disarmed.
It also enables you to check whether your car is safe when you're looking at your car from a long distance. If side-mirror is being fold, that means your car is successfully armed and locked.
*This function is only for luxurious car. (optional)
Remarkale new function installed!
"Just knock 4 digits pre-installed password, you can arm(Door close)/disarm(Door Open)" the car security system without remote Controller.
Sensor part built-in 10 LEDs can display various status depend on its function
YouTube- EASYCAR Introduction
YouTube- EASYCAR Smart Key System Function
YouTube- EASYCAR Smart door Function
YouTube- EASYCAR Easydoor Lock Function
YouTube- EASYCAR Other features
YouTube - Easy Door Lock YouTube - Smar Door YouTube- EASYCAR Auto Side Mirror Foldoing YouTube- iran TV ads
TFT - LCD
[E702AS-S] HOTTEST ITEM !!!
2-Way Communication
Modulation : FM(FSK)
Carrier Frequency : 433.92MHz
  • TFT LCD
  • Alarm
  • Alternator Engine Sensing
  • Anti-Grinding
  • Anti-Jacking
  • Auto-Arming
  • Auto Start
  • Aux Outputs
  • Diesel Powered Vehicle
  • Driving Door Lock
  • Dual Shock Sensor
  • Easy Door Lock By password
  • Engine Running Time
  • Extra Sensor Input
  • Hood Trigger Input
  • Keyless Entry
  • Long Pulse Of Lock/Unlock
  • Manual Transmission
  • Noise Engine Sensing
  • Onboard Relay Door Lock
  • Owner Call Mode
  • Parking Brake Input
  • Parking Lights Input
  • Parking Lights
  • Passive Arming/Locking
  • Propane Gas Powered Vehicle
  • Remote Paging
  • Remote Vibration
  • Shock By-Pass
  • Signal Lights
  • Melody Speaker
  • Starter Kill
  • Status Output
  • Time Clock
  • Timer Start (24H/3H)
  • Time To Rearming
  • Trunk Sensor
  • Turbo Mode
  • Valet By Key/Remote
  • Smart Key System
  • Key Knob
  • Smart Door
  • Easy Check Feature
  • Easy Option Setting
  • Auto Side Mirror Folding
  • Temperature Display
Package list
  • 1x TFT LCD 2way remote
  • 1x Melody speaker
  • 1x A5100 Antenna module
  • 1x M7000 Main control
  • 1x LF module
  • 1x Smart key knob
  • 1x Dual shock sensor
  • 1x Easy door lock
  • 1x Knock sensor
  • 1x LED Ass'y
  • 1x Tempearture sensor
  • 1x Leather case
  • 1x Wire hardness kit
  • 1x Hood switch
  • 1x User guide
  • 1x Installation guide
  • 1x Car window warning sticker
  • 1x Full colored gift box
TFT-LCD Transmitter Technology
Full Color Display, with easy to use scroll down menus for quick and easy function and option changes... The same technology used in Cellular phone display and lap tops
The newest and most advanced Alarm / Security and Remote Start Display ever..... The new Standard, From Easy Car......
TFT Full Color Transmitter display with easy to use scroll down menus.
Exceptional Telecommunications provide for the very best Range and immediate Response time.
Number one in Performance, Reliability, and Customer satisfaction.
EASYCAR is the leader in screen display and performance.Full color high resolution TFT-LCD(702) and OLED(602) displays are the most colorful, brightest, and brilliant displays ever plus easy to use, scroll down menus allow the user to easily change options and functions. The most advanced telecommunication systems promise exceptional range and immediate response on all two way communication.Plus, our two way telematics systems provide the user with easy to use push of a button system checks and status updates, for your vehicles’ safety and your peace of mind.
New 702 TFT-LCD Transmitter / Remote is available in a default Car display, or our new Truck Display. Ask your authorized dealer for Details. The wait is over...... The easiest to use, most intelligent two way Remote ever, From EASYCAR
Panic Mode
Your safety is of prime concern to us, and our advanced Research and Design Team at EASYCAR. Let our Panic mode become your smart and personal body guard.
Whether you feel threatened or just simply looking for your car in a crowded parking lot, by pressing and holding button “1”, your EASYCAR Alarm siren (or optional speaker) will sound off for 1.5 minutes, plus your vehicles’ lighting system will flash, alerting others of the situation, scaring off undesirables, or simply help you locate your vehicle. Plus, the system will automatically lock your vehicle once you are safe and inside......
Ask your dealer for details regarding EASYCAR Alarms and other security and safety features available
Remote Start
Manage your vehicles’ engine temperature and interior temperature; create your personal and comfortable interior environment. Hot or cold, EASYCAR’s fine range of remote start systems will control your vehicles’ heating or air conditioning systems.
Plus, EASYCAR’s long history and commitment to R&D, and cutting edge 433.92 MHz Telematics technology ensures that your Starter is completely operational at the longest ranges available today. FM communication response time is instantaneous, and remote battery life is the best in the industry.
EASYCAR’s high quality line of full function Remote Start Systems offer the most functions and features available today. Easy to use pop down menus make for easy changes to such things as your vehicles’ remote run time, easily choose between 15 or 25 minute run times.
Plus, our state of the art Turbo Timer function protects your Diesel Turbo engine from damage and costly repair. Just another way EASYCAR is bringing Auto Safety and vehicle management forward....
Turbo Timer and Engine Protection
Protect your turbo and diesel engine from damage and costly repair. Let EASYCAR’s software manage the cool down process.
It is no longer necessary to sit and wait while your engine cools, EASYCAR’s Turbo Timer will take care of the situation for you. We recognize that your time and convenience is important.
24 Hour Reserve Run time Mode
Easy to change options allow the user to utilize a 24 hour clock and establish a run time that is convenient to both you and your life style. Whether you or your transmitter is in range, your vehicle will start and warm when you need it. Plus, it shuts down relative to your preselected run time. For your safety, the 24 hour reserve mode turns off each time you depress your brake pedal.
EASYCAR, the ultimate convenience system.
Doors, trunk and your hood lid monitor and detection
EASYCAR leads the way in vehicle security
The industry’s highest quality alarm systems, monitor and detects doors, trunk and your hood lid, plus, our high quality adjustable dual stage shock sensor provide unparalleled security for you, and your vehicle.
EASYCAR alarm systems are adaptable to all vehicles, plus work optionally with each of our remote car starter models.
Start kill, Ignition kill
Offer the same great features as in our standard alarm security package, plus our Starter Kill.
Technology that ensures your vehicle can not be stolen, even if your factory key was to fall into the wrong hands. Your EASYCAR remote is required to access control of your vehicle. Adaptable to all vehicles and EASYCAR’s remote start systems.
The ultimate security and protection package.
Shock Sensor
Included in all EASYCAR alarm and security systems, easily adjustable sensitivity levels, provide for full and real time vehicle shock sensing monitoring.
Can be easily turned on or off, in the event your pet is left in the vehicle, and ultimate convenience for courier and content security. Shock sensor can be turned off, while your vehicle is armed and protected....
Siren Mute except for Panic, shock, Theft
Don’t wake up your neighborhoods in the middle of the evening with false alarms, eliminate the shock sensor monitoring with mute mode
Mute the siren / alarm relative to shock sensor monitoring, while leaving other and necessary security functions fully operational, including panic mode, door, hood and trunk monitoring
Query Function
Current vehicle status
EASYCAR makes it easy for you to check important functions associated with your Starter and Alarm System. With the click of a button, check important functions such as time, Interior temperature,
Communication signal strength, transmitter battery life, and more.
Auxiliary
EASYCAR’s auxiliary outputs allow you to control such things as your vehicles windows, sunroof, sliding doors, and stereo. Consult your authorized installer for details.
Owner Call / Knock Sensor
EASYCAR’s optional knock sensor serves as an easy to use paging system. Knock the sensor pad to alert and page the transmitter. Is of great value when someone is looking for you, and would like to meet you at your vehicle.
Ignition Lock
Security and convenience
Your vehicle locks 30 seconds after it is remotely started, and unlocks once the key is turned to the off position.
Valet Mode by Key / Remote
Useful when having your vehicle serviced, or when turning your vehicle over to valet management.
Turns off all Starter / Security functions excluding doors-lock or unlock
Trunk Release
Open your trunk lid as required with EASYCAR’s stand alone and separate trunk lid release button. Open your trunk lid without having to leave your vehicle. Useful for active families, couriers and much more.
Second Car control by one remote
Second car Function is used to operate two vehicles with EASYCAR remote car starter or alarm system with one remote.
Feel free to visit our website www.dbl-vie.yolasite.com and do not hesitate to email us [email protected] if you have any further enquiries.
DBL VIE AUTO TRADING
Call or SMS 016-5600953 016-6233712 014-7312223
*All materials, man power and its cutting edge technology are truely from Korea.
*No Modifications as all Accessories in the package set are manufactured and genuine from Korea.
*Our Products are provided with 2 years warranty.
http://i5.tagstat.com/image04/8/2f6d/001U051u2ZJ.jpg
