- Joined
- Nov 17, 2003
- Messages
- 1,606
- Points
- 3,148
ok :oOriginally posted by evo3@Sep 16 2004, 11:20
i c... thank you...currently running stock, boosting at 0.6bar....don have the intention to upgrade to bigger hp... :rolleyes:
to check if fuel pump is ok or not..U don'T have to do a dyno run...Originally posted by Danny@Sep 17 2004, 19:31
still advisable to go for dyno test especially when u are using an underpowered fuel pump. You may never know that it may be too lean during boost and in the long run would harm your engine.
same price yes..but on dyno run's just to check Hp's and afr..u will only know that your car is lean after the runs..its means only after your car has blowned then only u'll realised oh noo...was running lean all these while.. :lol:Originally posted by Danny@Sep 18 2004, 02:55
true la, can use wide band sensor also, but u pay almost the same as a dyno test. At least with the dyno test u can see the hp readings also.
yups if free means best gila man..Originally posted by khoyos@Sep 19 2004, 17:10
check AFR rm30, dyno with AFR reading rm100. big difference wor...
i check afr free, bcos my mechanic has wideband AFR sensor (plug at exhaust).
No prob la....Originally posted by vestax@Sep 19 2004, 23:41
friend friend kasi free only la :rolleyes: . then i belanja yamcha in ali maju okay ?
Originally posted by carcass+Sep 20 2004, 09:41 -->
QUOTE (carcass @ Sep 20 2004, 09:41 ) --QuoteBegin-vestax
@Sep 19 2004, 23:41
No prob la.... Member member FOC... [/b][/quote] wehh.. he dowan yamcha @ ali maju, or majid tak maju or whatever.. he want to go ehem ehem weh... :P :D :P ;) |
Originally posted by lekalo+Sep 20 2004, 11:21 -->
QUOTE (lekalo @ Sep 20 2004, 11:21 ) Originally posted by carcass@Sep 20 2004, 09:41
--QuoteBegin-vestax
@Sep 19 2004, 23:41
No prob la....
wehh.. he dowan yamcha @ ali maju, or majid tak maju or whatever.. he want to go ehem ehem weh... :P :D :P ;) [/b][/quote] Ohhh.....Swimming.... :lol: :lol: |
--QuoteBegin-vestax
@Sep 19 2004, 23:41
No prob la....
wehh.. he dowan yamcha @ ali maju, or majid tak maju or whatever.. he want to go ehem ehem weh... :P :D :P ;) [/b][/quote] yups lekalo u're right tak main la ali maju... ahemmm aheem ok ok la.. :lol: |
vestax for u tak de hal la boleh ceta la..Originally posted by vestax@Sep 19 2004, 23:41
here's the dynoOriginally posted by vteckiller@Sep 23 2004, 03:53
vestax stage 2 was new hks cams and injectors
stage 3 will NOT be internals, it will be larger throttle body and bigger intercooler, like that only la..as now still using stock 50something throttle body and stupid intercooler....
then stage 4 would be internals but that would be next year or maybe later...use this stock one first la....
MILLENNIUM FOREVER !!!
Take MC la....cakap sakit gigi.... :POriginally posted by ramsing@Sep 23 2004, 10:12
sigh, wasted i coudlnt make it for the dyno. couldn't escape from work :( bleh
Hi senior & knowledgable members ,
