DIY urethane engine mounting kit
kwfei28
Cheras
Good new for all racer boy. I have solution for those guys who experiencing of frequent mounting failure due to increased horsepower. I have 10 sets DIY engine mounting kit for sale. These kits are made from high quality urethane. Each set comes with preset ingredient and all you need to do is just mix and pour the urethane into your original mountings. Once harden in 2 days time, they will transform into a mounting like nismo is selling right now. This would not only make your mounting more solids but also increase of horsepower due to lesser engine movement. Each set is more than enough for 4 mountings in your car. They are imported from USA.
Don’t worry, they are not nylon or teflon that the engineering shop is selling right now. This is urethane formula, which allows some small amount of flex to avoid your car from cracking. There are 2 types of hardness. The soft one, which is suitable for daily driver, cost RM300.00 and the hard one, which is a even tradeoff between performance and comfort cost only RM280.00.
Interested, do call 012 3649649 (Fei) for inquiry.
Following attachments are the finished engine mounting from U13 turbo ready to be use.
Just for your knowledge, you still need to use your standard mounting as your base. In addition, you can still reuse your completely torn mounting by pouring this formula onto it. Only special care is needed to ensure centering alignment.
Description on how to do will be included into the package.
bro.. i have 2 mmc brand mounting for wira/satria. its for the front and back. theyr brand new. i wanna diy urethane them.. where to get the stuff?
Pal, drop me a call. We can make appoinment to meet at somewhere around Kl since we live in in the same neighbourhood. At the same time, I can show you a sample of finished wira mounting just to give you greater confidence on the product that you are buying.
Bro...
the item is ready to be purchase or still in ordering process??
Hi there, do you mix and install this too ? Or do you have any recommended place that can mix and install eh ?
Ong, you can do it yourself. I will include a description on how to do inside the box. What you do is only ask your mechanic to remove all your mounting and pour the formula into the mounting. That's it. Mixing is pretty simple . It is like liquid A pour into liquid B and then stir it. I can also recommend a shop to fix it for you but you have to pay extra for workmanship. Call me if you need further info. Bear in mind this material is exactly the material the Hansport USA mounting is using right now. Dont worry I am using it right now. Thanks.
Those who is interested but do not know how to do, I am offering them additional RM40.00 for labor charge. What they need to do is just ask their foreman to remove all their mountings from their car andmake appointment with me to collect around Cheras. I will return your mounting to you by the same day.
i wouldn't mind it but i prefer if you have someone to apply the mounting stuff for me.. got ah?
PM sent to Deacon. By the way I do offer such service but you need to pay extra RM 40.00. Thanks
I am not sure. Its totally depend on your driving habit. As far as I am concern, It is better than your ori.
