[DIY] How to decrease engine bay temperature
And DIY CAI as well.
attachment.php
that's a very cool CAI holder. Where'd you get this done / bought?
izso, that's not a cai holder la its an aftermarket air filter, go brothers can see a lot of those.
just cut some of the batang to fit the CAI
I agree not perfect CAI but atleast there are still a lot of outside air coming thru the hose.
Ha ha ha...I don't dare to do that...I don't want jay pee jay to be my good friend...
ha ha ha...yes agree with you...
Anyway whose car is that...I want to rolling on the floor right now...ha ha ha...
But I saw before someone install at his Odyssey a scoop with double hole....so daring...
hello guys need to know can this spray can also applied to engine block ?
where can i get ?
i want to spray my engine block to flat black any suggestion how to make it ?
I'm already take out all the internal part so need advise what spray can applied for block engine need flat black colour
:hmmmm:
where can i get ?
:hmmmm:
yepp sure can use 1, manifold is hotter than block maaa
where can i get ?
:hmmmm:
make sure the engine block is free from oil stain, grease or dirt. If not the paint wont stick properly and your spray paint will be a wasted effort.
Try engine degreaser. They are tough on heavy oil, grease, etc.
Most engine degreaser are petroleum base therefore you may need to use soap to wash the degreaser off also and then let dry kao kao first
Tq will buy engine degreaser this weekend, and wait for block coming back from machine shop after that i will start to build it back :burnout::burnout:
Sent to machine shop, come back should be quite clean, right? If not in the car you can clean with whatever solvents, rather than spray degreaser. Just make sure no dirt and oil before spraying
or u can go to hardware shop & try to find water based degreaser, ace should have lot for oil & grease, its spray leave rinse method.
