anyone know why the tcs, slip and check engine light is on when the engine is running? it comes on all of a sudden when i'm idle at traffic light. please help
ohh goshhh!! i got the same problem too bro!!
it was happen last 3months untill now.not even when idle,sometimes from the beginning when engine get started untill it dissappears itself..looks like the wiring or maybe some electronics devices goes wrong...anybody had this trouble before?? pls share with us..pleaseeeeeeee.....
i'm using bridgestone potenza front 215 rear 235, but didn't have this problem before. All 3 lights goes on - tcs, slip and check engine. i tried pressing the tcs switch but no response
Probably got 2 reason, 1 is unplugged sensor especially at rear bottom HICAS steering always unplugged by itself.
2nd is....import car, being disconnected frm battery wth the condition of steering wheel not straight at Yard parking.So ths reset HICAS ecu unproperly.
I suggest u:
1st: check unplugged socket at HICAS steering.
2nd: Reset ECU
3rd: Diagnosis (Nissan comes wth manual ECU diagnosis)
Rerider,
just wondering..the problem might because of the tyre size??how??explain pls..
sorry for asking this might be stupid question(as im still newbee)
kaminari,
thanks for the advices..will try to do it soon(hopefully)
kaminari thanks for the advice, i'm wondering if my dog has anything to do with unplugging the hicas, since you said it's probably unplugged. Damn, dog likes to play with its toys under the car.
The news has been brewing in the grapevines for some time now and reports once again indicate that Audi will be unveiling an R4 e-Tron roadster at the upcoming paris...
I recently changed my stock MR2 turbo's fuel pump with a Supra's. The engines stock and im using an SAFC. Will adding an FSE Fuel regulator give any advantage in any way? Is it neccesary?
