D1 Spec Oil Catch Tank 480cc
powerautohauz
((( God Level 30,000 RPM )))
D1 SPEC OIL CATCH TANK 480CC
D1 Spec Oil Catch Can is a must have for any performance vehicle!
D1 SPEC Oil Catch can catches the oil and moisture in the blow by gas that causes carbon and sludge build-up in the intake system and the engine. It keeps the engine clean even under hard driving conditions.
Engines are prone to accumulation of an oil sludge mixture forming inside the intake tract due to crankcase pressure and inefficient combustion. And although oil in the intake track is normal it can reduce engine performance.
The D1 Spec Racing oil catch tank will hold this oily byproduct by removing it from suspension within the air intake stream.
By doing so, horsepower is then increased by eliminating the engine’s current requirement to try and burn this relatively non-combustible oil. Engine life is extended due to this oil not having the ability to gum up the valve train and other moving parts and sensors. The surface been polished to a mirror finish, this easy to install catch tank is a must have for any performance vehicle.
Bakuso Racing Sdn. Bhd.
No.21, Jln PJS 11/24,
Bdr Sunway.
47500 Subang Jaya.
Land Mark:
Desmond 017-396 8567
Email us : [email protected]
