D.I.Y Automotive TOUCH UP PAINT
ezytouchup
Selangor
MALAYSIA No.1 ORIGINAL AUTOMOTIVE
D-I-Y TOUCH-UP PAINT !
Ezy Touch Up
- GOT STONE CHIPS AND SCRATCHES ON YOUR LOVED CAR’S PAINT?
- TOO EXPENSIVE TO SEND FOR REPAINT JOB?
- WHY NOT TOUCH-UP YOURSELF AND SAVE YOUR MONEY?
After Touch Up
Before Touch Up
> All the EZY Touch Up paints are mixed by computer system with original factory formulation
Providing the exact color appearance with the existing original paint.
> All the EZY Touch-Up Product’s quality achieves the OEM standard.
> There are more than 100,000 original factory formulations in our database.
> It’s simple and easy to apply, no professional skill needed, for application steps, please check here :http://www.ezytouchup.com/Direction-of-Use/q?cid=4&doit=showclass
Automotive Paint Structure
THIS D.I.Y TOUCH UP PAINT IS ONLY AVAILABLE ONLINE,
FOR ORDER PLEASE LOG ON TO : http://www.ezytouchup.com/EZY-COMBO-SET/q?pid=9&doit=order
FOR MORE DETAILS, PLEASE CHECK HERE:http://www.ezytouchup.com/FAQ/q?cid=6&doit=showclass
Ezy Wax & Grease Removal
it is important to clean the defect area with this special solvent. new paint may lifted up if the defect surface not well cleaned.
Ezy Clearcoat
All the automotive paint need Clearcoat as final protection just like human skin.
Basecoat require Clearcoat to provide weather resistant, gloss and shine finishing, durability and to match the original paint appearance. It's also helps protecting the basecoat from UV attack.
What is EZY Basecoat ?
Basecoat is the middle layer of automotive paint system which is the color layer. Basically there are 3 layers in car paint system, 1st layer is Primer which is directly contact to bare metal, 2nd layer is Basecoat which is provide color appearance, lastly finished by Clearcoat which is a layer of transparent coat that to protect the Basecoat from UV, weather, and provide glossy finishing.
Our paints have been tested and formulated to last if you really take good care of it. The durability should same as original paint.
Our paints can be applied and perform very well on surfaces of metal, plastic, rubber, fiberglass, PU, PP, ABS and wood.
clearcoat will completely dry after 24 hours.
* do not wax the new paint surface within 1 month
