i dun recommend u to DIY spark plug cable... cos u are dealing with high voltage cables.. n u may not have proper skills, tools n materials to insulate the high voltage cables properly... n if not done properly... it may create a shock hazard...
erm... those cables used for spark plug is diff lar...
grounding cables is for high ampere n low voltage... de insulation is just normal skin niah..
spark plug cable is diff... it is for high voltage n low ampere... de insultation is diff also.. skin is diff.. i think got some braided insulation also...
grounding cables are not suitable for this purpose..
i tried once....miss ffire all over cos of he voltage jumping between each others :)
so tat 1 failed.....so now in my iswara, wat i did is i let the core touch the connector directly, normally the core is connected to the conector by a plate..
What happen if the cables touch each other? Wouldn't it be hazardous? Imagine if your car is not properly earthed. It will give a massive fire and explosion if it hits the fuel line...
lets say we combine 3 4gauge cable for one plug
total up for 4 cylinder will use 12 wires..
like that spread teh load for different wire mar...
can do? :D
That is too much already la...imagine the thickness of combining a few 4ag cable...what u need is high voltage copper wire and good insulation...better get a reasonable pricing racing spark plug cable...
Hi there..
my car window just got crashed last night..it was an attempt to steal the car..
anyway, the only thing missing is my rsm as its been ripped off and my glass shattering everywhere in the car..
