coil spring problem?
hungJAcky
Hi all,
i just change a new set of bilstein b8 to replace my old leaking one, but after changing the absorber using the old lowered spring(not sure what brand but green in color), i found out that driver side is lower than the passenger side for the front. u can see the attachment.
So, is my spring spoil? and if i wanna change it, i would like to try H&R..
Thanks for reading ( :
hi all,
i just change a new set of bilstein b8 to replace my old leaking one, but after changing the absorber using the old lowered spring(not sure what brand but green in color), i found out that driver side is lower than the passenger side for the front. U can see the attachment.
So, is my spring spoil? And if i wanna change it, i would like to try h&r..
i think is normal because sometimes car is like that. Before you lowered, you cannot see but now your car is lowered, so you can see that 1 side high and 1 side low.
You shud go for H&R, price around 1xxx only...
