Item(s): MAGNAT BULLPOWER 2 Channel amp (original)
Package includes: amp itself, manual book, screw
Price: Market price:RM450+ BUT NOW >>>>> RM300
Warranty: 1 year
Contact method/details: 012-2649183 (or may be u will get the secret discount)
Age of item: brand new
here is the pic:
http://img523.imageshack.us/img523/9953/dsc08510am3.th.jpg
http://img168.imageshack.us/img168/7005/dsc08511xx3.th.jpg
http://img108.imageshack.us/img108/1534/dsc08512xr3.th.jpg
http://img204.imageshack.us/img204/9337/dsc08514dz8.th.jpg
Bulldog power with new form and technology. The new generation of Magnat's Bullpower range runs stable at 2 ohms, is equipped with variable duplexor filters, adjustable bass boost and subsonic filters. Solid head sinks and high-performance power supplies create the conditions for the unleashing of enormous power.
Magnat Bull Power Two
Max. power output into 4 Ohms - 2 x 130 Watts / 1 x 400 Watts
RMS power output into 4 Ohms - 2 x 65 Watts / 1 x 200 Watts
Max. power output into 2 Ohms - 2 x 200 Watts
RMS power output into 2 Ohms - 2 x 100 Watts
Technical Description
# 2 ohm stable
# Variable low pass 50 - 500 Hz (12 dB per octave)
# Variable bass boost 0...6 dB at 45 Hz
# Variable subsonicfilter 10 - 50 Hz (12 dB per octave)
# Low level pass through RCA jacks
# Bridge- / Tri-mode capability
# Gold plated RCA connectors
# Gold plated screw terminals for speaker and power supply
# Protection circuit that safeguards against short circuits, DC-offset and overheating
# Green operation and red protection indication LED
Max. power output (Sinus Burst 2:8, 1 kHz) into 4 Ohms, 14,4 V - 2 x 130 Watts / 1 x 400 Watts
RMS power output (DIN 45 324) into 4 Ohms, 14,4 V - 2 x 65 Watts / 1 x 200 Watts
Max. power output (Sinus Burst 2:8, 1 KHz) into 2 Ohms, 14,4 V - 2 x 200 Watts
RMS power output (DIN 45 324) into 2 Ohms, 14,4 V - 2 x 100 Watts
Frequency response - 5 Hz - 100 kHz (-3 dB)
THD - < 0,05 % (1 kHz)
Signal-to-noise ratio (A-weighted) - > 100 dB
Input sensitivity - 0,25 V - 4 V
Input impedance - 50 kOhms
Power Supply - 12 V negative ground
Dimensions (WxHxD) - 267 mm x 58 mm x 237 mm
Weight - 2,5 kg
HOT ITEM HOT SELL
thx for view..
Warranty: 1 year
here is the pic:
# 2 ohm stable
Weight - 2,5 kg
HOT ITEM HOT SELL
thx for view..
