clarion cd /usb/aligment player
ICE -In Car Entertainment
ben_hok
location jalan kelang lama batu 3
pls call ben 016-2228108
my site http://benhok.multiply.com
& http://ebaudiosse.multiply.com RM1180
DCP
Digital technology with awesome sound quality
The DXZ786USB focuses on high quality sound in the digital age. It features iPod® direct connection and compatibility with USB Digital Media Streaming capability, Digital Time Alignment Control along with a 3-way crossover gives you the ability to precisely balance the speaker positions in the vehicle for the optimum listening experience.
  • CD-R/RW ready
  • MP3, WMA and iTunes® AAC compatible
  • Rear USB connector with maximum track capacity: 130,560 (255 tracks in 512 folders)
  • WMDRM 10 playback for Digital Media Streaming
  • 18 FM, 6 AM station presets
  • iPod® direct control via USB
  • 6V / 6ch audio preout
  • Subwoofer level control
  • 24-bit D/A converter
  • Sound Restorer
  • Digital Z-Enhancer
  • Digital time alignment
  • 3-way active crossover
  • 3-band parametric equaliser
  • Built-in High pass filter & Low pass filter
  • Built-in amplifier canceller
  • 4-channel × 53 watts MOS-FET amplification
  • Motorized sloping console
  • 728-variable colour display and illuminated keys
  • Full dot display with Screensavers
  • "SLIDETRAK" for dynamic operation
  • Cellular input and Phone mute
  • Auxilliary input with level control
  • CeNET control of 6-disc CD changer.AUX Bluetooth transceiver BLT370 ready .OEM steering wheel remote wired interface capability
Direct USB iPod® control
You no longer need an expensive adapter box or interface cable to connect your iPod to your Clarion source unit. Simply connect the USB cable included with the iPod to the DXZ786RUSB rear USB input for battery charging and complete control of your iPod.
Rear USB connector compatible with WMDRM 10
The rear USB connector is compatible with the Windows Media Digital Rights Management (WMDRM 10) format for audio, video, and other data. The connector allows you to link to a USB compatible device to play music files in DRM 10 format that were purchased and downloaded over the Internet
* Use the USB cable supplied to connect the iPod.
* See the Clarion website for iPod models that can be connected
SLIDETRAK Sideways Control
Clarion takes HMI to the next level with SLIDETRAK for precise control of key features on the main unit.
Simply swipe your fingertip to easily adjust the volume.
Preset radio stations and CD track controls are also incorporated into the multifunctional display, so you can navigate through preset stations or select your favourite music track by sliding your finger to a side of the display.
SLIDETRAK also maximises available space on the main unit to create a large, easy-to-read display.
Bluetooth® ready
Handsfree conversations on Bluetooth ready mobile phones, supports greatly the safety in driving. Conversations are possible via wireless connection of the phones to the vehicle audio systems. With Bluetooth ready iPods, music reproduction from and control of iPods can be done through the main unit.
728 variable colours
Colour-tuning the look of your audio system is easy. Clarion also lets you fine-tune the look of your source unit with 728-colour illumination. Choose from 13 different preset colours to let the DXZ786USB slowly morph through the entire spectrum or fine tune the Red, Green and Blue levels to match your dash perfectly.
6-volt/6-channel output
Equipped with 6V/6ch outputs for reproduction of sources with high sound quality. Together with crossover settings, it can be used to output to various speaker systems like Front 2ch + Rear 2ch + Subwoofer 2ch.
Time Alignment
To achieve optimum sound positioning, ideally each speaker should be located equidistantly from the listener. However, it is almost impossible to realise this within the environment of a car. Digital Time Alignment works to virtually change speaker distances, thus creating a seemingly optimal sound field. Adjustment is possible from 0 to 501.4 cm in 2.3 cm steps
Separates the sound spectrum into different bands so you can minimise peaking and phase cancellation, which can result in muddy sound when using a 2-way or 3-way speaker system. Xover circuitry also optimises each output range, resulting in more natural and smoother transitions between ranges. And since it’s built-in, it requires no additional equipment or expertise. The cut-off frequency, filter, slope and phase can be adjusted for each band, enabling precise sound tuning. you can also set a Time Alignment value for each speaker for optimal sound matched to the vehicle’s acoustics.
SPEAKER SETTING
• Normal: F2ch + R2ch + SW2ch
• 3-way: HI2ch + MID2ch + SW2ch
• 2-way: HI2ch + MID2ch + R2ch
Enjoy digital media streaming
Support for audio compression formats such as MP3, WMA, and AAC, and digital rights management WMDRM 10 format, link with an iPod, and improvements in connectivity with USB devices - all these make it possible to seamlessly enjoy music with a variety of digital media.
Requires a portable audio player that is compatible with WMDRM 10 data playback.
SOUND RESTORER
Hear your music the way it was meant to be heard. Clarion’s Sound Restorer recreates the high frequency information that is lost during compression.
The result is clear and detailed sound.
Digital Z-Enhancer sound customisation
The Digital Z-Enhancer lets you choose from 3 equalisation patterns to restore tonal balance by freely accentuating each of the high and low frequency ranges. Thanks to 6-step gain adjustment of 3 separate preset patterns, tailoring the sound to your system speakers and the selected audio source is now possible.
A key component in the transfer of digital data from a CD into analogue sound is Clarion’s 24-bit D/A converter. Because the digital realm is made up of unnaturally square sound waves, as opposed to the smoothly undulating sound waves characteristic of the real-world environment, Clarion’s embedded 24-bit D/A converter recreates the natural nuances and expressions lost during the sound reproduction process.
2 band Parametric EQ
Dividing the sound spectrum into 2 bands, the parametric EQ allows equalizing of the frequency curve for customization of the sound character according to the speakers used and the acoustic properties in the car.
High Pass/Low Pass Filter
you can set the frequency range of the audio signal that's output to each channel, to best match the acoustic characteristics of the front, rear and subwoofer. This is also possible even if you decide to connect your original speakers directly to your main unit without an external amplifier. The High Pass Filter is also available to cut off frequencies below 50, 80 or 120 kHz.
Bump: bumpppppppp
Bump: bumpppppppp
bumpppp http://ebaudiosse.multiply.com
