Cheap Cheap SubWoofer
ICE -In Car Entertainment
SY Store
CL1220 Vamp II 12" Subwoofer
http://www.biz2u.com.my/gen/thumbnail_tpl5.php?i=http://www.biz2u.com.my/upload/files/product/images/A100144/20090930115554.jpg&w=500
* Vamp Generation 2
* Max power Output 200Watts
* Black Paper Cone With Foam Edge
* 12" Woofer
RM 80
MWW10001 10'' SUBWOOFER
http://www.biz2u.com.my/gen/thumbnail_tpl5.php?i=http://www.biz2u.com.my/upload/files/product/images/A100144/20091102123417.jpg&w=500
# Sensitivity: 86 dB
# RMS Power Range : 250 Watts
# Diameter: 10 Inch
# Dual 4 Ohm 2” BASV Aluminum Coil
# Vented Back Plate
# Mounting depth is 5.25"
# Priced per speaker
# Subwoofers are usually come as a single speaker unless noted differently.
RM 159
MW12003 - Ming Wei 12'' SUBWOOFER
http://www.biz2u.com.my/gen/thumbnail_tpl5.php?i=http://www.biz2u.com.my/upload/files/product/images/A100144/20091104132557.jpg&w=500
# Sensitivity: 88 dB
# RMS Power Range : 1000 Watts
# Impedance: Dual 4 Ohm
# Diameter: 12 Inch
# NBR-rubber surround
# Nickel plated 8 ga. compression wire terminal
# Conex/cotton composite spider
# Texture coat finish on stamped steel basket
# Vented back plate
RM 259
RP108 ROCK POWER 10 INCH SUBWOOFER
http://www.biz2u.com.my/gen/thumbnail_tpl5.php?i=http://www.biz2u.com.my/upload/files/product/images/A100144/20090727095017.jpg&w=500
* Frequency Response 40-1.5KHz
* Sensitivity 87dB
* Max Power 300W
* Magnet Weight 90oz
* Voice Coil 50mm
* Normal Impedance 4ohms
RM 179
RP128 ROCK POWER 12 INCH SUBWOOFER
http://www.biz2u.com.my/gen/thumbnail_tpl5.php?i=http://www.biz2u.com.my/upload/files/product/images/A100144/20090725135736.jpg&w=500
# Frequency Response 35~1.5KHz
# Sensivity 85dB
# Max power 500W
# Magnat Weight 90 OZ
# Voice Coil 50mm
# Nominal Impedance: 4 Ohms
RM 199
C12 Kicker 12" Comp Series SubWoofer
http://www.biz2u.com.my/gen/thumbnail_tpl5.php?i=http://www.biz2u.com.my/upload/files/product/images/A100144/20091123124220.jpg&w=500
Size (IN.,CM) 12, 30.5
Impedance (OHMS) 4
Max Rec Amplifier Power (WATTS PEAK/RMS) 300/150
Non Original Kicker
RM 230
Contact Us
Sun Audio 0124859343
