Carcony Fuel Saver Malaysia (ORIGINAL)
ORIGINAL CARCONY FUEL SAVER DEVICE INCLUDED DELIVERY:smokin:
What is Carcony Fuel Saver Device?
Q: CARCONY Vehicle Fuel Saver – What Are The Benefits?
Of course, when you buy CARCONY it is to save fuel save money! This device can effectively save fuel, improve torque and enhance the overall horsepower output. Normally, a family car’s average fuel consumption is about 8-9 liters/ 100 km, and if it runs 20,000 km a year, it will save approximately 320-450 liters of car fuel in about three years. It also stabilizes the electrical system, smoothens out the engine and extends the battery life. It will save you the trouble of repair and maintenance and save you the expense as well. In addition, it is highly beneficial to your health, as when it is installed in the car it increases oxygen content (Negative Ion), which in turn improves heart and lung function, feels more refreshing, and clear driving fatigue.
Q: Does CARCONY fuel saver enjoy easy installation? Do you need to change the oil or any type of circuit before it works?
Without changing the oil or adding any circuit, just plug it in the cigarette lighter holder. It is simple as it is safe as already tried and tested in Japan, the U.S.A., Singapore, Europe and other regions and countries. It is worthwhile to mention here that the fuel saver device enjoys EU’s CE certification.
Q: How does CARCONY fuel saver, reduce stress on the engine?
When you use CARCONY fuel saver, which is regulated by voltage stabilization technology to make fuel burn optimally, the carbon inside the cylinder will be significantly reduced, which in turn prolongs the life of the engine.
Q: What is a negative ion? What does it do?
“Negative ion” refers to a negatively charged oxygen ions, which is colorless and tasteless. Air is composed of numerous molecules and atoms. When the atoms or molecules in the air lose or gain electrons, they form little particles called ions; positive charged ion is called a “positive ion”; and negative charged ion is called a “negative ion”. The negative ion is often referred in medical profession as “air vitamin”. This is because this particle has the ability to purify the air inside the car, eliminate the odor making it smell refreshing and clean thus protect the health of occupants.
Q: Will by any chance CARCONY fuel saver car shorten the life of the battery?
In most cases people feel that if Carcony automobile fuel saver can have access to the energy generated from the battery, the device would normally consume battery power and hence, decrease the life of the battery. In fact, the opposite is true. Because Carcony is designed to regulate automobile fuel saving, one of its major functions is to provide backup power for auxiliary car electronic equipment, stabilize battery voltage – all of which will not only reduce the burden on the existing battery, but also extend its life.
Q. CARCONY fuel saver patents - Where Can It Be Found?
CARCONY has been awarded patents for the car fuel saver there are two:
(1) One patent is registered at national level (China) – Patent No.: 200920136517.8.
(2)The second is Design Patent No.: 2,009,301,771,006.5.
You can check about both on the national patent office website from where you could obtain detailed information.
Q: What Other Benefits Does Carcony provide other than conserving fuel?
First, it helps with the detection of battery health, and whether the circuit is working properly. Place the fuel saver into the cigarette lighter holder and you will instantly get a BLUE lamp lit. This light will burn bright blue as long as the car batteries, generators remain in the normal position; it will burn red light, which means that the car battery, poor generators need to send the car to electrical workshop for further investigation.
Second, it releases negative ions, which in turn improve the air around. The built-in negative ion air purification device (Built-loniz-er), is able to effectively eliminate the car residual formaldehyde, sweat and other bad odors, and produce a concentration of about 8 million/ cc. This so called “air vitamins” – increase oxygen content, to ensure a clear mind avoid fatigue driving, full health care owners.
Third, it stabilizes the vehicle’s voltage to avoid electrical fault. CARCONY fuel saver, not only prevents voltage sags, but also keeps all the electronic items safe from voltage fluctuation.. Therefore, Carcony is able to ensure that all of the electronic components stay safe and function optimally, inside the vehicle to operate in the best conditions.
attachment.php
attachment.php
Contact: http://www.CARCONYMALAYSIA.COM
FACEBOOK PAGE: CARCONY MALAYSIA FACEBOOK PAGE
https://www.facebook.com/carconyfuelsavermalaysia.com
REMEMBER: THIS IS ORIGINAL PRODUCT
