yesterday i set it with the vacum hose connected around 2.7bar. Then go test the car. but ho...i open the hood n check again...the pressure was go down around ~2bar. how come ha????:hmmmm:
then i adjust it back to 2.7bar again. tonight will try again without connect to the solenoid (direct to manifold) for the vacum hose.
it is a normal practice to set the fuel pressure without the vacuum hose connected. btw, did you properly tighten the lock nut at the adjustment screw ?
yups..i saw that also...only the part that i wondering is only around 2bar+ with vacum hose connected. that seem very low..hehhee
but if install this FPR then run away to kl for dyno tune also feel a bit waste..some more the petrol so high now..haiz..y mlc dont have dyno machine....
Hello all sifu out there. I have one question, should I get a Power FC ECU to fine tune the engine, do I still need a boost controller to adjust higher boost or the power FC can do everything?
