Car Engine Jerking
edwin_lcw
1,000 RPM
Setapak
Hi all,
Mind you guys sharing if your perdana did face any problem like mine ?
The engine jerk when going uphill or when temperature is hot like afternoon.
Previously I suspect the problem is from my spark cables and problem did settle after changing one set of original cables(so called lah), one set of cables from half cut and at last one set dunno what brand but its expensive around 300++
but after a year problem comes back again.
I somehow got this feeling its not the cables that makes this problem.
Any advise ?
u got check any hose leaking anot? check yr intercooler hose, o2 hose, etc.....make sure all tight.
but y halfcut plug cables so expensive? wat color? black or blue? brand?
new updates ... yes peter your right !!!
after checking with the V-sixers in Australia found out actually the spark plugs seal that blocks the engine oil from wetting the plugs worn out hence the plug is in total disaster
dunno how it affects but it really causes the plug to misfire and also the cable to die off too ....
now have to change all 6 seals and plugs ... no problem so far
Hi Team Memberz.
Actually my V6 also having the same issue jerking
When up on the hills. I would like to noe what is the
problem & how to get rid of it?
Need your assistance guys. Tq
