cant open my fuel cap liao
mynnDAWG
2,000 RPM
the "knob" to open the fuel cap from inside the car is not working la...wher to replace liao...:P
is the cable broken?if yes u can try to find it at chop shop.if cant get it then u can customise one
Mynndawg,
Are you talking about the "lever" to pop open the fuel tank cover? If so, have someone pull the lever and you go check whether the small arm moves or not on the inside of the cover itself. If it's not moving, then perhaps cable got disconnected somewhere.
I don't think it's something serious but if the cable alrdy snapped, then it's quite tricky to have it replaced. Not sure where the cable is lined up on your car but try to trace it.
Good luck
yeah its the lever la bro...damnit..now gotta haev at least 2 people on board the car to pump in fuel la..sey!
its not a hard thing to fix... dont worry man... !!! mine sometimes doesn't pop up as well... i usually insert something underneath the lever to keep it up so i can walk to the tank cover and open it manually... but it only happens to me sometimes...
I believe there is a spring on the cap itself. Sometimes, u just need to bent it a little just like what I did for my car. Or spend RM 10 for a used cap from the chop shop. Evo maybe a little expensive.
bro i had da same prob too last time on my e7... bought da ori mitsu spring for 30 bucks i think... now ok d...
i went to a sparepart shop in ss19 sj... they ordered from mitsu supplier... took a day to get it...
Speaking of which, how was their service ? The Mitsubishi in Jln Sg.Besi ? Maybe can pay them a visit one day. Their showroom seems quite huge also.
the person in charge for Mitsubishi really frenly la..kinda old dude...En. Kadir..
frenly & sourceful!...he loves evos btw...
suggested evo owners to send for check ups at the place...
