- Joined
- Dec 27, 2004
- Messages
- 12
- Points
- 3,001
Need help from any of the sifu out there... need to know wheter an rsm meter can be installed on carb car?
EFN said:RSM can be installed on carbed cars. No ECU does not mean it is a dead end.
BUT in order for the Speedo to work, the gearbox must be the type that send electronic signal - or most commonly known as Speed Pulse Signal. So if you can confirm that your gearbox is the one that emits Speed Pulse (to the Speedo Console), then u can tap RSM Speed wire into it. If your gearbox is pure mechanical type, sorry speed option will not be usable at all.
For RPM, connect the RSM Ignition Signal wire to the Ignition Coil directly, usually it is the -VE part of it. This should be very easy.
Hope this helps
Hope this helps
