Bushings Problem?
dvino
Calling all sifu’s,
I think it’s time for me to change my bushings for my car. I start to hear metal knocking sound when the car start to move and every time I go through a speed bump( especially front left side). I just gone through shoulder surgery (some mishap) so I can look down under the car for visual defects.The problem is I don’t know which one I should change (definitely front). Can any sifu recommend me which bushing should I change by time? I think none of the car bushing has been replaced before and it’s a 04 PFL model.
what else could cause such noise beside bushings worn out issue?
appreciate the input
Thanks
Hi Bro,
Just my 2 cents, if you really gona change your bushing, might as well change all front bushes, very hard to identify which part is worn and which not....but u still need to check how many bushes/part available for your car...and also worth noting - the labor charges is not cheap...but after change all the bushes, your car feel brand NEW again...then can fell in love with your car once more!
Yep change all the bushings then do on-wheel balancing and alignment then it should be good for 180km/hr drive.
