my friend using bt20V engine in his seg. when he the rpm reach 3k above, there's a sound coming out from valve cover. normally the tapet will giving sound but this one more louder. any recommend mechanic in seremban area?
Usually below 3000rpm its normal to have the diesel sound, but if half-throttle at below 3000rpm, the sound will disappear. If you are hearing sound above 3000rpm, then there's something wrong with the VVT pulley or maybe the engine is pinging (knocking). Knocking will sound like someone is knocking the engine with a screw driver.... LOL
hehe the sound will disappear and will apear again in some times.....
best way to test out is wit wat bro chinozie said ....unplug the VVT sensor cable ....then u test.....if problems still occur u try see ur distributor timing got lari or not lor .....
Anyone please help me...got pening kepala because my pomen already surrender. I got problem with my lancer Ck6A. I using evo 4 RS engine, but got semput-semput when tarik pickup.
All part was change but still...
