Bosch 044 fuel pump 390LH original germany
d&d performance
Beyond 20,000 RPM!
selangor
Bosch Motorsport Fuel pump 044
New In Box
300lph @ 5.0bar
This Fuel pump can support up to 650whp on 4 cylinder Turbo engine
Independent test results show the where the popular Walbro 255HP fuel pump flows 256 LPH at 30 psig fuel pressure, then Bosch 044 flows 290 LPH. This isn't really important though because most cars only see this pressure at idle. Now assume a vehicle running 30psi boost on 45 psi base fuel pressure (75 psi net fuel pressure). At this pressure the Walbro 255HP is flowing 208 LPH and the Bosch 044 is flowing 267 LPH (28% more capacity). Finally, at the top end of the chart (90 psi fuel pressure) the Walbro 255HP flows 156 psi and the Bosch 044 flows 253 LPH, which is 62% more!
Can send to anywhere via skynet or Gdex Express
installation can be done in
D&D performance s/b
-no.18&20,jalan pjs 11/7,bandar sunway,46150
petaling jaya,selangor,malaysia.
tel:+603-56380888
:+603-56370888.
fax:+603-56316888.
email:[email protected]
hp:+60163328136 seng
:+60162111820 kenny
:+60162173767 frankie
