Zth member,i would like to ask wht i need to buy then can bolt on turbo into putra engine...wht is the cost to bolt on turbo into putra engine..wht i stuff i need so can safely plug n play for putra engine..
if u can find 93t Turbo kits.. Turbine,extractor,I.cooler,injector +SAFC.. such would do it.. but i advised u change the head gasket n low com pistons just to be safe..
proton do sell ems turbo kit for 4g93 Na for GTi,putra n wira 1.8... u can try that.. but a bit costly..
Hey bro.. mine is correct wht..:regular_smile:
He wanna to BOT ma.. so the best way is to rojak it with gsr turbo lor..
Hei bro 7D,
If u wanna to make a monster wise will be different talk already..
For Plug and Play..
- Mivec Head
- GSR TD04 Turbo Kit
- Supercharged Piston
- Independent ECU
- Waste gate 46mm
So.. it will be more to monster liao..correct me if i m wrong...hahhahahah...
PowerQube Automotive workshop is now open at Sunway. It is associated with TOON ENGINE SHOP(Thailand) which is famous for building strong and powerful engines used for circuit and drag purpose...
