hyperxcess
8,000 RPM
BLOX Racing Aluminium Short Throw Shifter:
* Direct Replacement Billet Aluminium Short Shifter
- A true short shifter decreases throw by reducing the angle that the shifter shaft travels through during its stroke between gears
- By reducing the angle that the shaft travels through between gears, the distance that your hand needs to move between gears is also reduced
- In many cases, the shifter shaft is also re-designed to be shorter than stock thus creating a sportier look & feel, as well as aiding in reducing the linear throw length when coupled with the reduced angular throw
Specifics & Benefits:
* Provides Quicker, Reducing Shift Throw by 35 – 40%
* Coated with High Quality Polished T6061 Billet Aluminium for Enhancing Strength & Durability CNC Machined High Strength Durable Material
* High Performance JDM Racing Design
* Direct OEM Fitment or Replacement
* Retains Usages of Factory Shift Knob
APPLICATIONS :
- 1988-1991 HONDA CIVIC/CRX
- 1992-2000 HONDA CIVIC
- 1993-1997 HONDA DEL SOL
- 1990-2001 ACURA INTEGRA
BLOX Dual Bend Short Shifter --> Rm 95
BLOX Single Bend Short Shift --> Rm 85
APPLICATIONS :
BLOX dual bend alumium short shifter model 31361, single bend model 31360 (9).JPG23.8 KB · Views: 318 -
BLOX dual bend alumium short shifter model 31361, single bend model 31360 (10).JPG30 KB · Views: 142 -
BLOX dual bend alumium short shifter model 31361, single bend model 31360 (7).JPG24.9 KB · Views: 148 -
BLOX dual bend alumium short shifter model 31361, single bend model 31360 (2).JPG40.3 KB · Views: 150 -
BLOX dual bend alumium short shifter model 31361, single bend model 31360 (5).JPG39.6 KB · Views: 134
