wah..got so many people their car bought for them these days.
performance is most of new owners seek esp the younger gen.
they just seems to be attracted to the word performance.
i was like that in my early 20,but now i am driving a very2 lightly mod car only.
and...that lightly modded car do surprise some more powerful car once a while.
then again,most of the driver are youngster in their blindly modded car.
if the otai driver in zth...surely they left me to makan asap...
my car not a brand new one la....huhuhu...already 2 years ...everything working fine without any problem except power...feel little bit underpower since im used an automatic transmission.
Ha, keyword: Automatic.
You can't really enjoy the power be it 1.6 or 1.3 with AT.
I have 1.6 AT myself with 1300kg body.
Really really bad acceleration unless high rev (4-6500rpm)
can someone provide me roughly cost for this type engine conversion??
saga blm 1.6 crankshaft = RM???
saga blm 1.6 conrod = RM???
bolt on turbo kits = RM3.5k
anymore??
anymore??
but i plan to go with 1.6L stoker kits conversion......just watch on youtube....look really fast.. :vroam
flarery : save yourself from the trouble of working on an automatic 1.3L. Even if you made it pop 130hp, it will guzzle gas like a 240 Volvo and already at 50% of its life duration. By the time : you can only shred the weight of the car.
or cheaper : buy yourself a throttle controller to make it a little more responsive to the torque. proton's drive by wire system generally the main reason the performance sucks. And second : the punch CVT gearbox. the laziest gearbox I've ever met. Literally you want to downshift to overtake, you have to 'punch' it with high revs.
People see rubbish I see gem...Hohoho...i sense a top secret mod developement in process.....
on the 1.3 engine,i was expecting an improve of performance when using ron97 as its using high comp piston.what surprise me is that the performance is the same with ron95.
Not test want to build something out of it.As a test mule for future mods?![]()
anymore??
Beside what taikor gunners has mentioned. This is just my idea.
If you want to BOT your engine. Get the CFE block. The block is slightly different from NA block it is more sturdy and the water jackets are more IINM. dump in the 1.6 rods or if can get aftermarket rods which are stronger couple with 1.6 piston. Send the crankshaft for hardening process, fully balance it.
Or just get a halfcut CPS and swap it in...but STILL THE AT BOX HAVE TO GO!!!!
Actually maybe many don't know the 1.3 engine is very good at producing power. but you need patience and know how to extract that power out. Dyno proven (on Dyno Dynamics) with light mods...the 1.3 can output 95-97whp on a MT....I'm not joking ya....this figure is achievable with stock cams, stock ECU, stock injector, stock fuel pump....
Now also you have that engine, why not straight away proceed in building it?
CFE still new, so fast got halfcut? Using CFE block and internals is almost like swapping to CFE instead of BOT 1.3.![]()
