coolbuddy 3,000 RPM Senior Member Joined Apr 30, 2007 Messages 3,375 Points 1,638 May 5, 2007 #1 hello to all daihatsu owners...help me!!! what offset can fit to aura??? max-min thanks.....
- D i a b l o - 500 RPM Senior Member Joined Sep 27, 2005 Messages 695 Points 1,528 Location Shah Alam May 5, 2007 #2 i think max is 42 for g100
A anonymous4477 Known Member Senior Member Joined Dec 30, 2006 Messages 192 Points 1,518 May 7, 2007 #3 max - 43 min - 38
O onyx Known Member Senior Member Joined Mar 8, 2005 Messages 301 Points 3,016 May 7, 2007 #4 yeahhhh corect min must be - 38!!! if not kena ketuk body!!!!
Maxx 2,000 RPM Senior Member Joined Feb 17, 2005 Messages 2,072 Points 5,148 Location PD-Putrajaya-KL May 7, 2007 #5 depends on rim size also, especially width. if 15"x6.5". 38-40 will be the best. some fender rolling might be needed. 14" maybe no problem.
B brutus Known Member Senior Member Joined Feb 7, 2005 Messages 87 Points 3,006 May 29, 2007 #6 i hv a set of 6x14 et35 wit 175/65 oso need 2 kutuk d rear mudguard a bit. i tot avoiding 185/60 wud solve d problem.
teztozterone Known Member Senior Member Joined May 18, 2006 Messages 381 Points 1,516 May 29, 2007 #7 max i think is 45 la dudes 14" deto mah...lol
Maxx 2,000 RPM Senior Member Joined Feb 17, 2005 Messages 2,072 Points 5,148 Location PD-Putrajaya-KL May 29, 2007 #8 brutus said: i hv a set of 6x14 et35 wit 175/65 oso need 2 kutuk d rear mudguard a bit. i tot avoiding 185/60 wud solve d problem. Click to expand... urs offset to much, 35mm. so need to ketuk/roll the fender. lower offset number more "terkeluar" the rim and tyres. higher more "ke dalam".
S spsmotosport 500 RPM Senior Member Joined Oct 18, 2005 Messages 788 Points 1,516 May 31, 2007 #9 to kawansejuk... i'm using 15 x 6.5" with max offset 42... i've used 14 x 6" with min offset 38.. Last edited: May 31, 2007
