Audison SRX2s 2 ch amp for sell
ICE -In Car Entertainment
alan1975
Singapore
Amp still in good working condition, looking to sell RM 700 neg.
Here are all of the specs for those that don't know how to search.
POWER SUPPLY
Power supply voltage: . . . . . . . . . . . . 11 ÷ 15 VDC
Idling current: . . . . . . . . . . . . . . . . . . . . . . . . . 0.9 A
Idling current when off: . . . . . . . . . . . . . . 0.002 mA
Musical max consumption: . . . . . . . . . . . . . . . 35 A
AMPLIFIER STAGE
Distortion –THD (1 kHz; 4 Ohms): . . . . . . . . 0.03 %
Bandwidth (-3 dB): . . . . . . . . . . . . . . 4 Hz ÷ 50 kHz
S/N Ratio (A weighed @ 1 V): . . . . . . . . . . . . 95 dB
Damping factor (1 kHz, 4 Ohms): . . . . . . . . . . . 280
Pre In input sensitivity: . . . . . . . . . . . . . . . 0.2 ÷ 5V
Speakers In input sensitivity: . . . . . . . . . . 0.4 ÷ 10V
Pre In input impedance: . . . . . . . . . . . . . 15 kOhms
Speakers In input impedance: . . . . . . . . . 100 Ohms
LOAD IMPEDANCE:
2 ch. . . . . . . . . . . . . . . . . . . . . . . . . . . . 4 - 2 Ohms
1 ch . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4 Ohms
NOMINAL OUTPUT POWER (RMS)
NP @ 12VDC; THD 0.3% 4 Ohms:. . . . . . 135W x 2
OUTPUT POWER (RMS) @ 13.8 VDC; THD 1%:
- 2 ch (4 Ohms) . . . . . . . . . . . . . . . . . . . 180W x 2
- 2 ch (2 Ohms) . . . . . . . . . . . . . . . . . . . . 300W x 2
- 1 ch (4 Ohms) . . . . . . . . . . . . . . . . . . . . 600W x 1
FILTERS/INPUTS
Inputs: . . . . . . . . . . . . . . . . . . .Pre In / Speakers In
Outputs: . . . . . . . .Pre Out (hi-pass/bypass/lo-pass)
Filters: . .12dB-24dB/Oct., hi-pass / bypass / lo-pass
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .50÷350 Hz
Lo-pass switch: . . . . . . . . . . . . . .stereo (12dB/Oct)
. . . . . . . . . . . . . . . . . . .mono (24dB/Oct) / bypass
Q control:
(on hi-pass) . . . . . . . . . . . . . . . . . . . . . . . .Q 0.7÷2
OTHER FUNCTIONS
Remote IN: . . . . . . . . . . . . . . . 7 ÷ 15 VDC – 1 mA
Connections for VSR kit
for SUB remote volume: . . . . . . . . . . . . . optional kit
Fuse: . . . . . . . . . . . . . . . . . . . . . . . . . . . strip, 30 A
Protection: . . . . . . . . . . . . . . . . temperature >85°C,
DC voltage, overload
Green-red LED indicators: . . . . . . . . . . . . on-safety
Cooling fan: . . . . . . . . . . . it activates from 55°C on
