Atp engine oil stop leak
Apache91120
Klang
Engine kereta anda 'makan' minyak hitam?
Selalu nak kena top up?
Minyak hitam leaking?
Oil seal / gasket bocor?
Sekarang tidak lagi! Gunakan ATP ENGINE OIL STOP LEAK!
AT-205 Re-Seal is a fast, effective and safe stop-leak for all rubber seals and gaskets. The exclusive formulation restores worn or dried out seals and is not harmful to internal bearings and components.
Professional strength fast acting resealer, stops leaks fast
Rejuivinates all rubber seals & gaskets in engines, transmissions, power steering, differentials and hydraulic systems
Compatible with conventional and synthetic oils, ATF, gear oil, power steering fluids and hydraulic oil
Does not contain petroleum distillates, will not over-swell or breakdown seals
8oz bottle will treat a 6 quart capacity
AT-205 Re-Seal - How it works
AT-205 added to leaking system
AT-205 Re-Seal is added to any leaking engine, transmission, power steering system, differential or hydraulic system (except for brakes) to condition rubber seals/gaskets and stop leaks. Simply pour it in as you would be filling it with oil or fluid.
The formulation blends with the oil
The additive blends with oil in the system and is circulated throughout during operation, treating and conditioning rubber seals and gaskets
Conditions and rejuvenates seals
AT-205 is a plasticizer, a type of chemical used in rubber manufacturing to set hardness and flexibility. As a seal or gasket gets older it can dry out, harden and wear - treating it with AT-205 will rejuvenate it, restoring it's flexibility and sealing properties.
Most leaks resealed within 5 hours
As long as the seal or gasket is not severely damaged or torn, the leak is resealed after a total of 5 hours of driving - saving time and money from costly repairs.
MADE IN USA.
WHATSAPP: 012-9154001
