ARP Head Studs
ARP Head Studs
andysky5
((( God Level 30,000 RPM )))
ARP Head Studs
Obtaining the optimum cylinder head-to-block sealing is especially critical in small displacement engines employing high compression pistons or power adders like turbochargers, nitrous oxide and superchargers. That's why ARP® head studs are popular among leading Sport Compact/Import racers.
You should know that ARP® uses a premium grade 8740 alloy that is rated far superior to "aircraft" quality. Then, each stud is precisely heat-treated to 200,000 psi. Following heattreat, each stud is centerless ground to make it as close to perfectly concentric as possible. This procedure involves about ten very slight cuts and results in an exceptionally straight part. It's important to note that lesser quality studs are not even centerless ground the material is thread rolled in bar stock form (mostly before heat-treat, when the material is easier to machine). Because ARP® studs are manufactured to such exacting tolerances, you will note that gaskets and cylinder heads literally glide into position and are perfectly aligned something that won't happen with inferior quality head studs.
Made in USA.
Available : 4g92/93 GSR, Evo123, VR4, B16a, B18c/B20b, 3sgte, 4age 16v/20v etc.
We also provide main studs and con-rod studs for certain engines
Price : rm490 onward
Interested pls. pm or call : 017-3526055 (andy)
Dealing method : COD at Rev Performance @ No.7, Jln PJS 11/24, Bandar Sunway (1st Floor, on top of F3 Racing) or Send by Postlaju.
Operating Hours : Monday to Saturday ( 11am - 7pm )
CLICK HERE to check out my other sales Item !! :burnout:
017-3526055 (andy)
http://www.zerotohundred.com/newforu...-sales-36.html
017-3526055 (andy)
017-3526055 (andy)
---------- Post added at 04:15 PM ---------- 6 hour anti-bump limit - Previous post was at 02:10 PM ----------
017-3526055 (andy)
017-3526055 (andy)
---------- Post added at 04:44 PM ---------- 6 hour anti-bump limit - Previous post was at 12:14 PM ----------
017-3526055 (andy)
017-3526055 (andy)
---------- Post added at 03:53 PM ---------- 6 hour anti-bump limit - Previous post was at 12:04 PM ----------
017-3526055 (andy)
017-3526055 (andy)
017-3526055 (andy)
017-3526055 (andy)
017-3526055 (andy)
---------- Post added at 05:05 PM ---------- 6 hour anti-bump limit - Previous post was at 12:44 PM ----------
017-3526055 (andy)
017-3526055 (andy)
017-3526055 (andy)
017-3526055 (andy)
http://www.zerotohundred.com/newforu...ml#post3108056
017-3526055 (andy)
017-3526055 (andy)
017-3526055 (andy)
017-3526055 (andy)
017-3526055 (andy)
017-3526055 (andy)
017-3526055 (andy)
