SAE 10W-40 XL Extended Life Synthetic Motor Oil
Extended-Drain Boost Technology
Formulated for up to 10,000-miles/six month intervals, or longer when recommended in owners’ manuals or indicated by oil monitoring systems. Provides better wear control, high- and low-temperature protection and increased fuel economy compared to conventional oils.
AMSOIL XL Extended Life Synthetic Motor Oils provide better wear control, high- and low-temperature protection and increased fuel economy compared to conventional oils. Formulated with extended-drain boost technology, AMSOIL XL Synthetic Motor Oils provide superior performance for up to 10,000-miles/six months, or longer when recommended in owner’s manuals or indicated by electronic oil life monitoring systems.
AMSOIL, the leader in automotive synthetic lubrication, produced the world’s first API-qualified synthetic motor oil in 1972. Trust the extensive experience of AMSOIL, the First in Synthetics®, to do the best job protecting your engine.
During normal engine operation, the combustion process creates acidic by-products that can lead to internal component corrosion and a reduction in the life expectancy of the engine oil and engine itself. Formulated with extended-drain boost technology, AMSOIL XL Synthetic Motor Oils employ high-quality synthetic base stocks and a unique additive chemistry to neutralize acids longer than conventional oils. The extra additive package effectively raises the Total Base Number (TBN), a measure of an oil’s useful service life, and provides superior protection and performance throughout the entire drain interval.
Lower Maintenance Costs
Cost-conscious motorists, business owners and fleet managers benefit from the extended drain intervals and wear protection of AMSOIL XL Synthetic Motor Oils. While frequent oil changes are expensive, time consuming and inconvenient, longer drain intervals reduce costs and environmental impact, while increased wear control can reduce maintenance costs. With AMSOIL XL Synthetic Motor Oils, motorists realize the convenience and cost savings of extended drain intervals while also providing vehicles with maximum protection.
Improve Fuel Economy
Formulated with friction modifiers, AMSOIL XL Synthetic Motor Oils are fuel-efficient oils that reduce friction-related energy loss. They provide better fuel economy compared to conventional, non-fuel-efficient motor oils.
Maintain Low Emissions
AMSOIL XL Synthetic Motor Oils are friendly toward modern emissions control systems, promoting proper operation of catalytic converters for optimum service life and low exhaust emissions.
Hot- and Cold-Engine Protection
AMSOIL XL Synthetic Motor Oils are multi-viscosity formulations. Compared to conventional oils, they better resist the effects of thermal breakdown, including evaporation and viscosity loss, while remaining fluid in cold temperatures for easier cold starts and fast start-up circulation.
Keep Engines Clean
Fortified with detergent and dispersant additives, AMSOIL XL Synthetic Motor Oils are engineered to resist sludge and carbon deposits better than conventional oils. They promote clean operation for longer-lasting, better-running engines.
Bid Appropriate
AMSOIL XL Synthetic Motor Oils fulfill the requirements of most public and private purchasing bids. They are cost effective, making them ideal where synthetic motor oil is specified.
APPLICATIONS
AMSOIL XL Synthetic Motor Oils are excellent for use in all types of gasoline-fueled vehicles. They are recommended for all domestic and foreign vehicles requiring any of the listed performance specifications:
XLO 10W-40 Synthetic Motor Oil
API SN, SM...; ACEA A1/B1
MIXING AMSOIL
AMSOIL XL Synthetic Motor Oils are compatible with conventional and other synthetic motor oils. Mixing AMSOIL XL Synthetic Motor Oils with other oils, however, will shorten the oil life expectancy and reduce the performance benefits. AMSOIL does not support extended drain intervals where oils have been mixed.
Aftermarket oil additives are not recommended for use with AMSOIL XL Synthetic Motor Oils.
SERVICE LIFE
In gasoline-fueled vehicles, AMSOIL XL Synthetic Motor Oils are recommended for up to 10,000-mile/six-month oil change intervals or longer when recommended in owner's manuals or indicated by electronic oil life monitoring systems. Change aftermarket, original equipment manufacturer or AMSOIL Ea Oil Filter at every oil change.
HEALTH & SAFETY
This product is not expected to cause health concerns when used for the intended application and according to the recommendations in the Material Safety Data Sheet (MSDS). MSDS’s are available upon request at 715-392- 7101 or on the AMSOIL Website. Keep Out of Reach of Children. Don’t pollute. Return used oil to collection centers.
Bakuso Racing Sdn. Bhd.
No.21, Jln PJS 11/24,
Bdr Sunway.
47500 Subang Jaya.
Land Mark:
Desmond 017-396 8567
Email us : [email protected]
Keep Engines Clean
Bid Appropriate
APPLICATIONS
MIXING AMSOIL
SERVICE LIFE
HEALTH & SAFETY
Bdr Sunway.
47500 Subang Jaya.
Land Mark:
