AMS A45 CLA45 GLA45 Heat Exchanger
3,000 RPM
Penang / Butterworth
DESCRIPTION
From the factory, you can expect your Mercedes-Benz A45 AMG to produce a high level of boost pressure (27.5psi as tested). This in turn, creates extremely high charged air temperatures prior to entering the stock liquid cooled heat exchanger (intercooler). Although adequate under normal driving conditions, the stock heat exchanger responsible for cooling this boosted air underperforms when your A45 is driven aggressively, in warmer climates or when subjected to extended operation.
Get The Most Power From Your A45 AMG
Whether you are running stock or upgraded components on your 2.0L M133 turbocharged engine, the Alpha Performance Mercedes-Benz A45 Heat Exchanger Upgrade offers much greater efficiency – providing consistently cooler boost temperatures while combatting heat soak issues. Beneficial throughout everyday driving, this level of cooling is even more crucial to consistent performance on a road course or dragstrip.
An upgrade to the factory heat exchanger in both overall size and efficiency, ours offers better cooling of the intercooler system fluid. Being 38% larger than stock our heat exchanger core provides additional liquid capacity for greater heat dissipation. This allows the system to maintain lower fluid temperatures throughout extended periods of high throttle operation. To improve flow and reduce pressure drop, our engineering team went a step further by tapering the inlet and outlet for smoother flow. All of this will result in cooler intake air charges and maximum power!
Serious Buyer Only.
postage can be arranged.
R.S Enterprise - PRO Niaga Store on Mudah.my
We ship worldwide
if you are interested please call me at
Alan 012-4038323
https://api.whatsapp.com/send?phone=60124038323
