aloi@aluminium welding...help!!
afiq_farami
Dear forumer,
I just bought 2nd hand intake velocity. But the inlet hose has bend and almost broken due to poor shipping. Where the workshop in klang valley can repair? since it is aloi@aluminium material.broken heart when see the damaged.
try checking with GME Racing... they do alot of aluminium work
http://www.gmeracing.com.my/
try check nearby machine shop (where they do head skimming and block rebore or atleast radiator repair) usually those place have alloy weld...
What a poor shipping method by the seller. Should complain to them about it bro.
Yeah, I agree with Pomen_GTR, if you wanna find a cheaper alternative, then just find a radiator repair shop. They normally cater these type of welding and it's cheaper too.
Heads up though. Make sure you supervise them because some of the welders are foreigners (bangla's and Nepalese) and they just do a cincai work. Mine was just a minor crack so I don't need long quality welding.
Done..I have send to engineering workshop with total cost rm35..fire with flame to straighten and then weld the hole..Now, in stage to touchup with spray can..:burnout:
how much if they just weld only?? how they caj...per inch..or per electrode/ filler rod...or sumting??
i also need to weld my bro in law's aluminium radiator...any recomendations around ampang area?
They charge a rod aloy welding even 1/10 used. But total cost about RM35
---------- Post added at 02:59 PM ---------- 6 hour anti-bump limit - Previous post was at 02:57 PM ----------
not sure for area ampang.
