Airtrek Turbo for newbies....
Displacement, cc 1997
Engine model 4G63T (turbo)
Max.power (Net), kw(PS)/rpm 240 ps (176.52 kw) / 5500 rpm
Max.torque(Net), N*m(kg*m)/rpm 35.0 kg*m (343.23 N*m) / 2500 rpm
Power density 6.33
Engine type Serial 4 cylinder DOHC16 valve IC turbo
Engine information
Fuel system ECI-MULTI (electrically controlled gasoline injection)
Turbocharger Turbo with intercooler
Fuel type Unleaded premium gasoline
LEV system (Low emission vehicle) Yes
Compression ratio 8.8
Bore, mm 85
Stroke, mm 88
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 10.5
Power density 6.33
Engine information
Bore, mm 85
Stroke, mm 88
Final gear ratio
Thanx.. Any differences in the internal materials? How bout cam angle n lift if compared to an Evo 7 or 8?
Btw, how's your 6A13TT...?:burnout:
bro,
i got light right foot n was doing 70% h. way n 30% town.
What a clean and shining TREK.
thanx bro... but not everyday clean bro as i work at Penang 2nd Bridge construction site... i think u should know as i see u are from BM.. :biggrin:
---------- Post added at 01:28 PM ---------- 6 hour anti-bump limit - Previous post was at 01:26 PM ----------
bro,
i get u... i managed to get 14.5L/100km instead of 15.8L/100km with a lighter foot... but i guess the lower FC comes from me changing the air-filter and de-cat the Trek..
since this thread is for titled for newbies, may I ask what is fuel pump rating (Lph) of stock Airtrek 4g63T turbo? Thanks. =)
as a reply to "dummy7"'s PM to me about my FC, here it is..
normal use, i'm getting about close to 13L/100km.. highway use average about 10L/100km.. so i guess the FC is not bad...
btw, note that when i got the car the FC was very bad, almost averaging at 16L/100km.. after changing the air filter to K&N and removing the cat-con, the FC was better..
