Main Forums
Interests
Do-It-Yourself Garage
Aircond Problem...cfu's..help!!
<blockquote data-quote="simefly" data-source="post: 766468" data-attributes="member: 11753"><p>I think RM50 is enough for the mech to take it out and check la. If he is honest then he would point out the exact damage la, otherwise.. you could also ask for alternative that the thing will last for 1-2 months before you have money to change la...</p><p></p><p>The last time when my cooling coil bocor and i din have enough moolahs, this mech actually ask me to buy a packet of bubble gum and started to chew.... so what he did was he find the leak, stick it... use some kinda putty or hardener to top it up. He said it will last two months and it really did only last two months!! hehehe</p></blockquote><p></p>
[QUOTE="simefly, post: 766468, member: 11753"] I think RM50 is enough for the mech to take it out and check la. If he is honest then he would point out the exact damage la, otherwise.. you could also ask for alternative that the thing will last for 1-2 months before you have money to change la... The last time when my cooling coil bocor and i din have enough moolahs, this mech actually ask me to buy a packet of bubble gum and started to chew.... so what he did was he find the leak, stick it... use some kinda putty or hardener to top it up. He said it will last two months and it really did only last two months!! hehehe [/QUOTE]
R35 Used Titanium Exhaust
Autobahn Experience Part 1 : Audi A4 1.8 TFSI M/T rental car
http://a5.sphotos.ak.fbcdn.net/hphotos-ak-ash4/s720x720/283129_10150737294480352_902185351_20126121_7288123_n.jpg
Mein Damen und Herren (Ladies and Gentleman), I have recently returned from Germany and I have been...
4g93 Tuning on the siemens VDO
hi, I have a 272 cam on my SGTI running on Siemens VDO. As I know, you can't reflash the Siemens VDO.
I have been asked to changed all the wirings to MMC, including throttle body plus cam sensor.
Are there any...
Cams Questions
Hi all,
Not sure if this was asked previously. Can I use an intake cam as an exhaust cam i.e. running 2 intake cams in a 3sge?
I read from this page (http://www.alltrac.net/phpBB2/viewtopic.php?t=14440) tht this...
sn964444
Main Forums
Interests
