[After12] DEI Radiator Relief (Performance Coolant)
MAX_TorQue
7,000 RPM
Welcome to AfterTwelve E-Garage!!!
We do shipping internationally / COD / Credit card accepted.
We provide installation and painting as well.
Some item's price quoted below including installation or painting.Please take note.
Any kit that you are interested but not listed here, please contact us.
For order/enquiry, please contact JACK 012.312.7113.
Please CLICK to visit: AfterTwelve E-Garage
Contact JACK 012.312.7113.
Performance Radiator Relief
DEI's highly acclaimed Radiator Relief line has expanded with the addition of several thermal additives designed to increase the cooling efficiency of any stock or aftermarket radiator. Reduce engine temperatures up to 30°F with new anti-foam formulas using corrosion inhibitors.
Today’s gasoline and diesel powered motors aren’t as efficient as we’d like them to be but using DEI’s Radiator Relief thermal chemicals can increase the cooling systems efficiency of any vehicle by working with the radiator to lower engine operating temperatures up to 30°F! Before you upgrade to a performance fan or larger radiator try DEI Radiator Relief products. Now available for gas and diesel engines!
-To reduce the surface tension of the coolant
-With Anti foaming Agentwhich maximizes the thermal transfer process through the cooling system
-To reduce the need for bubble removal tank
-New Anti-Corrosion Formula that prevent rust, mineral deposits and corrision which can cause overheating and potential radiator core damage.
-Reduces pre-existing scale build up on your radiator and extend life of cooling system.
-Radiator relief is safe will alloys aluminium, is 100% biodegradable, water soluble, non-corresive and non-toxic.
Made in USA
Price: RM65.00
More info pls visit:
Design Engineering, Inc.
How to use:
Directly pour into radiator since it is compatible with any kind of coolant or use without coolant is possibe too.
Our suggestion:-Use radiator flush to clean your radiator.
-Pour in new water into radiator.
-Add in DEI Radiator Relief or add with any other coolant as well.
Tested and proven by my ride:
Toyota 1JZ 2.5 Twin Turbo Engine
Testing 1
Highway constant speed 140KMh, outsite temp 33
Normal Water temp 86,
With Thermal Spray 84
With Thermal Spray and DEI Radiator Relief 82
Testing 2
Highway Full Throotle until 260 KMh, outsite temp 33
Normal Water Temp 93
With Thermal Spray 90
With Thermal Spray and DEI Radiator Relief 88
Data above as a reference only.
