so far no one call to order, you're the 1st, so you're on.
the rear I still give you lar, since you drag race, may be useful to you :)
you're right, the slightly heavier GTE will need harder springs and absorbers.
But, the springs are around 8kg/mm - I think it's still too much for street use.....
BTW, I'll be giving you the HELPER springs as well, but I seriously recommend not to use it .......
The ride height will become very high after this .......
Using the helper spring will reduce the ride height, but the top absorber stroke will not be supported by the main coil and the absorber will behave alone ..... so becareful here, very non-linear behaviour.
Unless the car is really really heavy........
track, drag .... sure cun :)
street sure sucks :( gf complain :(
